16.5 wheels?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 06-28-2010, 10:02 PM Thread Starter
Firefighter/EMT
NH OIL BURNER's Avatar
16.5 wheels??
I recently got my hands on some 16.5 ford wheels which are 12in wide i believe...I am pretty sure they will bolt to my truck but i will def need flares. My question is how hard are 16.5 tires to get, i have looked online a bit and came up with very few of them. my plan is to level my truck and run 35x12.5 16.5s...any info whether it be good or bad is appreciated!
Jeff
02 F250 6 speed with 270k- SOLD
05 F350 auto with 94k, 4in MBRP with 6in tip, updated fuel pressure spring, and auto meter fuel press, boost, trans, and pyro guages, and tuning by vivian and PHP's FICM tuner currently running hercules! NO STUDS!
14.1 @ 95 is the best so far!
NH OIL BURNER is offline
post #2 of 8 (permalink) Old 06-28-2010, 10:10 PM
they call me tater salad
jawsfx4's Avatar
Re: 16.5 wheels??
i know all of the newer tires there is a pretty weak selection of them like the nittos and the toyos but the tires that have been around for a while like the super swampers and the ground hawgs there is a pretty big selection of them.at least there used to be
08 white cclb 4" straight pipe into 8'mitre cut black stack,dpf delete,egr delete,arp studs,6" fabtech lift,metal mulisha wheels wrapped im 37" toyos,sct running extremex,kenwood double din running two ten inch type r through a m1000,homemade front and rear bumpers, beamers hids
jawsfx4 is offline
post #3 of 8 (permalink) Old 06-28-2010, 10:50 PM
black7.3's Avatar
Re: 16.5 wheels??
junk the wheels!!!! 16.5's are a pain to find tires for............
03 F-250 all black CCSB 4x4 7.3, 4" straight pipe, DIY Intake, Boost, Pyro, and Trans. gauges, 07 harley headlights. 4" lift, 35" bfg's
79 F-150 351M, 4x4 headers and some other goodies, The camo truck
black7.3 is offline
post #4 of 8 (permalink) Old 06-29-2010, 12:30 AM
Re: 16.5 wheels??
its easy to find tires seach the internet you can find alot of tires. I had 4 sets of 16.5 rims
jersey250 is offline
post #5 of 8 (permalink) Old 06-29-2010, 12:42 AM
Re: 16.5 wheels??
Shouldn't be to hard, my boss has run 35x 12.50 bfg mud terrains, all terrains, and super swampers on his 16.5 by 9.75 wheels.
2016 F550 6.7 9' Dump work truck
2006 F350 6.0 Auto 95k miles. Sct programmer. 5 inch exhaust. Blue spring mod. Suspension mods and 35's.
1997 F350 7.3 Reg cab. Exhaust, coolant filter, front 2.25 PMF Rsk with Superduty Leafs.
gtmustang00 is offline
post #6 of 8 (permalink) Old 06-29-2010, 12:59 AM
montana350's Avatar
Re: 16.5 wheels??
if you decide to sell the wheels pm me i am looking for a set
2000 F-250 factory forged, six speed, 6" lift 37's on 20's, DP f-6,
montana350 is offline
post #7 of 8 (permalink) Old 06-29-2010, 03:58 AM
Re: 16.5 wheels??
check out interco they had several options when i bought them for my f-150, i think BFG has some too, or you could find some military tires for cheap from the hummer but they are bias ply i believe
00 Excursion. TS 6 position chip, AEM Intake, 4" Turbo back exhaust, wicked wheel, Transgo tugger, Gauges, 8" BDS Lift w/37x12.50.
JoesEX is offline
post #8 of 8 (permalink) Old 06-29-2010, 04:02 AM
<<< Dewey
Goose1995's Avatar
Re: 16.5 wheels??
check craigslist i just bought a whole set of bfg a/t in 35 12.50s for a 16.5 with 90% tread for 200 bucks
Jacob
1995 f250 powerstroke 4x4 4in lift 35x12.50s--SOLD!!
2001 ctd Dodge 2500 4x4, SB dd clutch, tst comp/ez stack leveled 20x12s blah blah blah
Goose1995 is offline
