Early 99s show em - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 06-15-2010, 05:15 PM Thread Starter
99whitetanpsd's Avatar
Send a message via AIM to 99whitetanpsd Send a message via Yahoo to 99whitetanpsd
Early 99s show em
lets see those early 99s
E99 f250 4x4 CC SB (sold)
7.3L powerstroke
292hp 658tq
[email protected] 1/8 mile
06 ram 2500 4x4 qc sb
5.9L 24V cummins
Originally Posted by Deereman4020 View Post
Fuk D-maxes I'll get a cummins before a D-max.
99whitetanpsd is offline
post #2 of 25 (permalink) Old 06-15-2010, 08:00 PM
All done now
Arisley's Avatar
Re: Early 99s show em
Before:
After:
Arisley is offline
post #3 of 25 (permalink) Old 06-15-2010, 08:57 PM
HP Junky
RockinJW is offline
post #4 of 25 (permalink) Old 06-15-2010, 09:05 PM
Peon
jvencius's Avatar
Other than the badge placement, what's so different about e99's from any of the '99-'05 trucks that you want a separate thread about them?
jvencius is offline
post #5 of 25 (permalink) Old 06-15-2010, 09:07 PM
thats what I was thinking.
02 f250
countryboyrob is offline
post #6 of 25 (permalink) Old 06-15-2010, 09:20 PM
Gone Broke
Stroker96's Avatar
Before:
After:
08 F-350 CC SB King Ranch 4x4
H&S Black Maxx 300 tune, Unlimited Intake, 6" Exhaust, Fuel Nutz wrapped with 295 Trail Grappler's
2000 F350 6spd Powerstroke For Sale!
UNLIMITED DIESEL PERFORMANCE
Stroker96 is offline
post #7 of 25 (permalink) Old 06-16-2010, 08:55 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Early 99 has a wicked wheel in it from the factory.
The early99 has 120cc(AB code) injectors and the late99-03 has 140cc(AD code) injectors.
The early99 has 2" intake runners. The late99-03 has 3" intake runners.
The early99 has a 15* swash plate HPOP. The late99-03 has a 17* swash plate HPOP.
The early99 has one glow plug relay. The late99-03 has one glow plug relay and one air intake heater relay side by side. Both relays are on the passenger side valve cover toward the front of the truck.
The early99 has a totally different air filter that is not inter changeable with the late99-03. But you can put the late99 air cleaner assembly in the early99 truck. The only three aftermarket air filters that work on the early99 are the AFE stage 2, the AIS and the KWIKK 6637.
The early99 track rod has smaller mounting bolts than the late99-03.
The early99 has shallower rotors than the late99-03.
The early99 has shorter hub-bearings than the late99-03.
The early99 front axle U bolts are square where they go over the spring pack. The late99 U bolts are round.
The early99 has a different pitman arm than the late99-03.
The early99 does not have the AIH like the late99-03.
The early99 does not have the automatic transmission fluid cooler in the radiator.
The early99 has no indicator light showing that "cruise" is on. Late99-03 has a cruise light that will come on when you set the cruise control. The early99 truck has the light in the dash already. A newer PCM(Yes it will plug in and will run better too) must be used to make the cruise light illuminate. It is a green light on the right side edge, half way up.
last year
build date 3/98
this year with Harley lights
Ron's power stroke is offline
post #8 of 25 (permalink) Old 06-16-2010, 05:00 PM
me2
I really need to remove the body molding...
New truck.
08 F350 King Ranch
Long box CC 4x4
6.4 5R110
Soon to get a Cummins 6.7 transplant.
Old truck.
Red '99 2WD F250 CC SWB
3rd gen 325/610 Cummins, ZF6
Custom air ride suspension
me2 is offline
post #9 of 25 (permalink) Old 06-16-2010, 05:08 PM Thread Starter
what did u need to get that 05 bumper to fit?
7.3L powerstroke
292hp 658tq
5.9L 24V cummins
post #10 of 25 (permalink) Old 06-16-2010, 09:42 PM
F350 Balla
Send a message via AIM to 4eyedconekiller
I present to you FLUFFY! It's a work in progress, so ignore the little imperfections, lol.
'99 F350
-DIY aFe Big Boost, MBRP 4",DI Tunes, ISSPROs, Sonnax/Tri, HD Headlights/5000k HIDs, Tinted tails, Painted XL Grille, Moulding/multiple emblem delete
-Tunes by Alpine, Boston Acoustics, Memphis Audo, and Audiobahn.
Look for drop, 22's, bedcover and wrapping up the dechrome
4eyedconekiller is offline
