recon cab lights vs factory cab lights - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 06-04-2010, 09:14 PM Thread Starter
which one is the better set i need the wiring harness as well the recon kit cost 90 dollars and the ford kit is going to be about 135 dollars is the ford kit worth the extra money
17 years old
2003 Ford F-350 ccsb
will.fuller is offline
post #2 of 6 (permalink) Old 06-04-2010, 10:43 PM
Send a message via AIM to Barnbuilder
Re: recon cab lights vs factory cab lights
I would imagine the Ford is better quality. I purchased the Dodge recon lights and the wiring harness was pretty cheap.
1999 F350 CC XLT 4x4 6spd
2006 F350 CC KR 4x4
Barnbuilder is offline
post #3 of 6 (permalink) Old 06-05-2010, 01:11 AM
F-25000's Avatar
i just got recon lights off of ebay for 70 bucks and they look great and came with every thing i needed
2004 F-250 regular cab long box, 6.0 w/ 6 speed, 4" turbo back exhaust, airaid airfilter, SCT, Sinister coolant filter, ARP studs, EGR delete, gauges- sold
2010 F-350 crew cab short bed Lariat. 6.4l with auto trans. Deleted and tuned.
Dylan
F-25000 is offline
post #4 of 6 (permalink) Old 06-05-2010, 01:30 AM
QUITTER :)
txpsd's Avatar
I did the exact same thing as Barnbuilder. I didn't even buy a wire harness, just tap a hot wire to your running light switch and run a ground wire splicing into each light. Looks great IMO!
2000 FORD F250 4x4 CC with !BTS TRANNY! BDP CR CUMMINS< 'Nuff Said.
BDP Nutt Swinger
txpsd is offline
post #5 of 6 (permalink) Old 06-05-2010, 02:37 AM
cshsrh's Avatar
Recon then use their 6 led wedge bulbs.....bright as hell front and back...All though not real sure why I need amber lights to the rear......
cshsrh is offline
post #6 of 6 (permalink) Old 06-06-2010, 11:12 PM
smokinstroke's Avatar
recons all the way
04 f-350 sct x2, 3in lift w/35in toyo m/t and 20x12 weld dune 8, recon cab lights, straight piped, FCDP egr delete,06 front end and 08 tailgate
smokinstroke is offline
