Tow Haul & 4-Wheel Drive Launch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 05-25-2010, 01:34 AM Thread Starter
I was just wondering what is the proper way to use the two haul and 4 wheel drive setting to get a quick launch? Do you just put it in 4 wheel drive and tow haul and leave them one through the whole run or do you turn them off as soon as you get going? Or should you not do either of them?
2003 F-250 Super Duty 7.3L, AFE Stage 2 Cold Air Intake, AFE Intake Manifold, AFE 4" Turbo Back Exhaust, DP Tuner F6 (40Tow, 80Econo, 120Race), Snow Performance MPG MAX Water/Methonal Injection, Adrenaline HPOP, Zoodad Mod.
Cessnakid is offline
post #2 of 15 (permalink) Old 05-25-2010, 01:36 AM
Young'n
powerstrokeracing's Avatar
Re: Tow Haul & 4-Wheel Drive Launch
Never done the tow haul on a launch but i wouldnt do it. and 4wd is a good idea to launch in but it will not disengage until you let up on the pedal or it will slam out one of the two.
powerstrokeracing is offline
post #3 of 15 (permalink) Old 05-25-2010, 01:51 AM Thread Starter
Yeah from what I've heard the idea behind using the tow haul is that your TC will lock up sooner, giving you better acceleration.
post #4 of 15 (permalink) Old 05-25-2010, 02:27 AM
<- Sums it up
strokin_early_99's Avatar
You have a 7.3 with tow/haul? Or are you referring to the OD lockout?
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #5 of 15 (permalink) Old 05-25-2010, 02:40 AM
TARM's Avatar
IIRC the last 7.3 in 03 had it. I could be wrong but seem to recall seeing it. For the most part I see it on the 6.0 5R100s
TARM is offline
post #6 of 15 (permalink) Old 05-25-2010, 03:01 AM
<- Sums it up
According to page 120 and 123 of the owners manual for the 03, tow haul is on the 6.0 and not the 7.3.
http://www.motorcraftservice.com/pub.../03f23og5e.pdf
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #7 of 15 (permalink) Old 05-25-2010, 03:04 AM
TARM's Avatar
Well there ya go. I know I had seen them on 03s but with the engines change mid year is was a bit confusing. funny thing is they were still using the 4r100 in 03 on the early 6.0 so it must be a PCM change only.
TARM is offline
post #8 of 15 (permalink) Old 05-25-2010, 08:52 PM
Village Idiot
southmike's Avatar
Could always time it, and see
But you will have to turn it on or off really ,to get your od gear
Otherwise you will hit the rev limiter and defuel.
Personally I just use 4wd.
southmike is offline
post #9 of 15 (permalink) Old 05-25-2010, 09:02 PM
Sponsor
04stroker's Avatar
Very fun to launch in 4wd but very good way to break stuff I've learned the hard way.
HOLDERS DIESEL PERFORMANCE
Building and flowing 6.0 injectors in house
holdersdiesel.com
04stroker is offline
post #10 of 15 (permalink) Old 05-25-2010, 09:14 PM
6.0 220k..4"silverline tubo bak..k&n ..sctw/custom tunes egr delete 35" bfg km2 on black bullet holes
ford: 97 350 389k r.i.p murdered by semi. 93 1st gen lighting 351w afr's,holley,ford racing
06stroker250 is offline
