New pyro reads hotter than old one? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-24-2010, 01:00 AM Thread Starter
Stroked Smoke
tls390's Avatar
I just installed some ISSPRO EV1 gauges. I had older versions of isspro that came with the truck. When I installed the new pyrometer it seems to read 100-200 degrees hotter than the old one. I used the probe that came with the truck (isspro). When I purchased the new one I did not get a new probe. Could this be the problem? Has anyone else experienced this?
2000 F-250 Crew Cab Shorty Auto 4X4 (116,000)
4" Lift 35's
EBPV delete, AIH delete, Foil delete
TS performance 6 pos (custom tunes from Rockin-S)
4" Exhaust
Ice Box intake
Tru-Cool and BTS Valvebody
Coolingmist Water
1.0 housing and turbo master
tls390 is offline
post #2 of 9 (permalink) Old 05-24-2010, 01:02 AM
2006nytro's Avatar
Re: New pyro reads hotter than old one?
is your old set for sale?
2006nytro is offline
post #3 of 9 (permalink) Old 05-25-2010, 02:39 AM Thread Starter
Stroked Smoke
tls390's Avatar
not sure yet. want to make sure the new ones will work.
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #4 of 9 (permalink) Old 05-25-2010, 02:43 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
You installed a new set of EV1 gauges or EV2's??? kinda important...
Do you have "amp" boxes or not...
Joe
CSIPSD is offline
post #5 of 9 (permalink) Old 05-25-2010, 06:55 PM Thread Starter
Stroked Smoke
tls390's Avatar
EV1 with amp boxes
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #6 of 9 (permalink) Old 05-26-2010, 10:54 PM
svnmpwr's Avatar
ive had the same problem
2000 cc/sb lariat 4x4
5in turbo back, 6637, van turbo, swamps sticks, adrenaline hpop, itp RR, wildman tuned, 4in lift, 39'' michelin xml's
svnmpwr is offline
post #7 of 9 (permalink) Old 05-30-2010, 10:58 PM Thread Starter
Stroked Smoke
tls390's Avatar
Do you find anything wrong or contact Isspro or am I in for another pyro?
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #8 of 9 (permalink) Old 05-30-2010, 11:08 PM
99psd-white's Avatar
i have EV1 and i like them alot because they do the job in monitoring my engine, they are my first set of gauges and if they are reading 100-200 degrees hotter than what my egts really are im really not going to complain one bit! I run down the highway according to the gauge at 850 degrees. And never get above 1200 degrees when really trying to get on it and racing. So im happy that they maybe reading hotter than normal!
1999 CCLB 4x4
6.5" pro comp lift
37" bfg KM2
18" muzzi hulk wheel
Isspro gauges
6.0L trans cooler
DP tuner
straight pipe
AIS intake
05 front clip
Ladder bars
BDS steering stabilizer with duel Bilstein shocks
UWS tool box
Hide-a-way gooseneck hitch
Built trans
CCV mod
Zoodad mod
Amp steps
99psd-white is offline
post #9 of 9 (permalink) Old 05-31-2010, 08:04 PM
chrome04strokin's Avatar
Just curious but why would you want to run gauges if they do not read correctly? And how do you know that your truck isnt running what the gauges are reading at?
chrome04strokin is offline
