detroit locker or detroit truetrac? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 02-02-2008, 09:18 PM Thread Starter
Work and Play...
brent's Avatar
Rearend is gonna need some work soon. I am wondering what is gonna be better for my 02 f-350 crew cab. The truck is a daily driver that does some towing and hauling. I want to fix the rearend the right way the first time with no regrets, but also want posi. Does anyone know the pros and cons with either locker?
brent is offline
post #2 of 22 (permalink) Old 02-02-2008, 09:44 PM
Evil Genius
DCSpecial's Avatar
Re: detroit locker or detroit truetrac?
Pros of Detroit locker: Extremely strong, always sends power to both wheels if you are on the throttle.
Cons of Detroit locker: Can be tougher to drive in the snow/ice, can make noise when it engages and disengages, while making a turn your inner tire will chirp or spin if you are on the throttle.
Pros of the Trutrac: More predictable on snow/ice, no harsh engagement or noise, unlike other limited slips there are no clutches to wear out, more street friendly than a Detroit locker.
Cons of trutrac: Not rec. for tires over 38", not a Detroit locker.
My $.02
DCSpecial is offline
post #3 of 22 (permalink) Old 02-02-2008, 09:58 PM
CamTom12's Avatar
I'd agree with all that. I ran a Locker in my TA and corners were a bitch. If you're on an on-ramp and you lean into the throttle the whole car kinda shifts when it locks up. Oh, and don't coast into a parking space with a sharp turn, CHUNKA-CHUNKA-CHUNKA! hahaha
It did good for what it was meant for though, being indestructible. I'd recommend the TrueTrac
CamTom12 is offline
post #4 of 22 (permalink) Old 02-03-2008, 12:32 AM Thread Starter
Work and Play...
brent's Avatar
So it is safe to say that you get the benefits of the detroit locker but with better driveability, and no sacrifice in durability?
brent is offline
post #5 of 22 (permalink) Old 02-03-2008, 12:43 AM
Evil Genius
DCSpecial's Avatar
A Detroit locker will give you better traction and strength.
A trutrac is strong (again, only rec. for 38" tire max.), offers good traction and better driveability. For towing and hauling with a daily driver, this would be my choice between the two.
post #6 of 22 (permalink) Old 02-03-2008, 05:26 AM
HarleyEdition78412's Avatar
Cool Re: detroit locker or detroit truetrac?
Actually per the truetrac owner's manual (here) the tire diameter can only be maximum 32" (page 1, operator's column):
"Distribute the load evenly side-to-side; do not
exceed the vehicle's rated payload capacity;
keep the diameter of the tires equal (max
diameter 32 inches). Failure to observe these
measures can create a difference in side-toside
wheel speed which can cause the vehicle
to pull to one side."
I found this out while looking for something to put into my 2001 that had 35x12.5s on it and ended up buying the D. Locker instead because of it. Never installed it, still have it but I'm considering throwing it into my 2006.
Current- 2006 Harley Davidson Edition F250 6.0L w/a "BUILT" engine, Unfortunately mis-assembled and installed by CenTex Diesel and a NAPD Heavy Hauler RACE SERIES Transmission
Previous- 2001 Platinum Edition F250 7.3L
SCT LW and FICM tuning-
Regulated Return fuel kits-
ENOUGH SAID
HarleyEdition78412 is offline
post #7 of 22 (permalink) Old 02-03-2008, 07:15 AM
OBS junkie
Cat_Rebel's Avatar
My buddy runs a Detroit Locker on the back & a Detroit True Trac on the front of his 79 Bronco with 38 TSLs. In the mud it has no problem spinning all 4 wheels & he is hard on it too.
I think for most normal everyday driving the true trac would be just fine. The locker is more if you want to make sure you get 100% lockup.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 22 (permalink) Old 02-03-2008, 02:50 PM
Evil Genius
DCSpecial's Avatar
I can't remember if it was on this board or another....but someone emailed Eaton (within the last 3 weeks) and the response from Eaton was 38" max.
Either way, there is a member on FTW running a trutrac with 41" Iroks...
post #9 of 22 (permalink) Old 02-03-2008, 03:34 PM
Corona Killa
THEDIESELMAN's Avatar
I love my Detroit locker wouldn't trade it for anything else if you don't want it to make noises learn to drive with it and you wont know you have a locker in the rear. The only time it makes a noise with me is if I get on it in reverse while turning but even then its not everytime other than that you wouldn't know I had a locker in my truck. A locker might not be for everyone but it is the only diff for me.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #10 of 22 (permalink) Old 02-03-2008, 06:38 PM
Send a message via AIM to Barnbuilder
Are the Detroit and Eaton units the same?
1999 F350 CC XLT 4x4 6spd
2006 F350 CC KR 4x4
Barnbuilder is offline
