obs 8 lug to 1999 lug pattern - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-14-2010, 02:03 PM Thread Starter
I have a friend who has a set of weld racing wheels chevy,early ford wheel patttern. Has anybody ever change or bored these to fit 99 superduty metric 8 lug pattern. Can this be done????????????? Thanks
kip4234 is offline
post #2 of 4 (permalink) Old 05-15-2010, 03:49 PM
Re: obs 8 lug to 1999 lug pattern
I have seen it done think it was on TDS but it was the other way where a guy took Excursion rims and machined them to 6.5". I think what he did was machine them and put steel inserts as the holes are real close like 2.5mm apart or so. Thinking cost maybe significant if you don't own a machine shop like he did???
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #3 of 4 (permalink) Old 05-15-2010, 05:48 PM
can't remember where i seen them but some place sells adapters to go from 6.5 to 170 and vice versa. somebody else might chime in that knows forsure.
2006 f-250 ext cab swb, 127,000mi, Egr delete, 4" tb exhaust, edge juice w/ cs.
Ryan
dp_stroker is offline
post #4 of 4 (permalink) Old 05-15-2010, 10:20 PM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
swap axles
CCLB with some stuff done .....
BigRed97 is offline
