Paint questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-10-2010, 01:58 AM Thread Starter
<--before leveler & block
stroker2's Avatar
Paint questions
Ok well im going to repaint my truck soon because the paint is scratched and the clearcoat is coming off on the hood in a spot. Its been repainted before but they didn't do a good job on it at all. The paint scratches really easy. i can scratch it with my finger nail somewhat easily. I want to stay with the same color and wondering how i would go about doing that. Do i have to buy paint from ford or can i do it from somewhere else? What is the best paint and primer? And what should i take off the truck to paint off? mirrors, grille, bumpers etc. Do windows need to be taken off? What grit of sandpaper should i go down to? 320 grit? how many coats and should i get clearcoat or buy a paint with clearcoat in it? Thanks in advance
2000 7.3 F-250 4x4 CC/SB Lariat 6-speed, 2.5" leveler and F350 block, Swamps 200/30% injectors, Swamps tunes, GTP-38R, Valair: kevlar/ceramic clutch, 4inch exhaust, AFE stage 2,
DFA-regulated return, pre-pump mods, Isspro boost and pyro, scan gauge, ~420hp and 836tq
stroker2 is offline
post #2 of 8 (permalink) Old 05-10-2010, 08:04 PM
Diesel Sled Head
zx800x's Avatar
Re: Paint questions
I removed any part that can be removed. Bumpers, all mirrors, all weatherstrips, grill, rear window. When I painted mine. Go to your local parts store and buy paint and I think 320 is plenty to sand down to.....
2001 f250 H2E,BTS,Stealth,reg return,mod IDM, spearco,DI Ceramic Headers.. bcode stage 3's Cale's Tunes
zx800x is offline
post #3 of 8 (permalink) Old 05-10-2010, 08:49 PM
NevrKnow's Avatar
Re: Paint questions
I want to know too. The whole inquiring minds thingy.
2002 F-250 SD Lariat CC 4x4
7.3L automatic.
Underdash gauge pod with ISSPRO gauges.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
4" turbo back straight exhaust and 4-6" Silverline chrome tip.
20" wheels with 32x12.5 Toyo MT's
'08 aluminum rear diff cover.
SOLID AXLE front cover.
A/C Mod
NevrKnow is offline
post #4 of 8 (permalink) Old 05-10-2010, 08:50 PM
F-25000's Avatar
Re: Paint questions
i wouldnt even sand the paint all the way off, just break the gloss and paint over it
2004 F-250 regular cab long box, 6.0 w/ 6 speed, 4" turbo back exhaust, airaid airfilter, SCT, Sinister coolant filter, ARP studs, EGR delete, gauges- sold
2010 F-350 crew cab short bed Lariat. 6.4l with auto trans. Deleted and tuned.
Dylan
F-25000 is offline
post #5 of 8 (permalink) Old 05-10-2010, 10:02 PM
MINK
Comp7.3's Avatar
Re: Paint questions
really you can just sand the hole thing down with 800 then seal wherever you broke through the paint, then apply base/color to the sealed spots then clear the entire truck with a good 3 coats...alot of people do it diffrent ways..
Josh Mink
CAMB MOTORSPORTS
Comp7.3 is offline
post #6 of 8 (permalink) Old 05-11-2010, 01:23 AM Thread Starter
stroker2's Avatar
Re: Paint questions
i think the only parts i am going to go down to the steel on are the tiny dents where i am going to lay bondo very thin. deepest dent is probably 1/8" deep maybe just a hair more but not as deep as 1/4". Is it bad to lay bondo that thin?
And thanks for you input so far!
stroker2 is offline
post #7 of 8 (permalink) Old 05-11-2010, 01:37 AM
6speed6oh's Avatar
Re: Paint questions
like zx800x said remove as much as possible, 800 would be good to sand it down with. wet sanding is a good idea. you can go to a paint shop and if its the same color as stock they can take your vin and match the color. prep work is almost the key part to make a good paint job. and at least three coats of clear. the windows shouldnt have to come out but it will make it easier in the long run. and as far as best paint and primer goes, you get what you pay for.
03 6oh, 6speed, regular cab, 4" turbo back, afe stage2, little bigger turbo,SCT, 35" cooper STT on chrome 18" rims, RUNS ON THE TEARS OF POR PEOPLE!
6speed6oh is offline
post #8 of 8 (permalink) Old 05-11-2010, 02:23 AM Thread Starter
stroker2's Avatar
Re: Paint questions
Ok cool. What do you think some of the best paint would be? Is Dupont any good? The truck has been repainted before. i hope to get really close to the color it is now because i think its a real nice color.
stroker2 is offline
