Do I inject ONLY Distilled water? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-04-2010, 03:44 PM Thread Starter
A Ghost these days...
farm boy's Avatar
Do I need to use only distilled water in my cooling mist system, or can I just use filtered water?
Also, what water soluble oil are ya'll mixing in the water? And where are you getting it?
Thanks in advance,
Clayton.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #2 of 8 (permalink) Old 05-04-2010, 04:06 PM
Drink til she's cute
Thuglike's Avatar
Re: Do I inject ONLY Distilled water?
You can use filtered water. I use regular spring water from the grocery store.
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
post #3 of 8 (permalink) Old 05-04-2010, 07:43 PM
Layson's Avatar
I run distilled when I actually have it, otherwise it has came straight from the hose...
Layson is offline
post #4 of 8 (permalink) Old 05-04-2010, 07:45 PM
Banning Smut
PTSUPERD's Avatar
I ran distilled water and water soluble machine oil.
Boost referenced.
Also...look into the optional shunt valve...
PTSUPERD is offline
post #5 of 8 (permalink) Old 05-04-2010, 08:06 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Must have the shunt valve... MUST...
Otherwise tap water is what I run... Over 200k on water injection.
no lube needed.
Joe
CSIPSD is offline
post #6 of 8 (permalink) Old 05-04-2010, 08:33 PM Thread Starter
farm boy's Avatar
no lube needed.
Boost referenced.
Is this it? Water Injection, Methanol Injection, Alcohol Injection Systems: Coolingmist By definition, this isn't it. But, I cant find anything else. Can you guys help me out.
Thanks for the replies. Im gonna run filtered water.
farm boy is offline
post #7 of 8 (permalink) Old 05-04-2010, 09:09 PM
CSIPSD's Avatar
Thats the one...
Joe
CSIPSD is offline
post #8 of 8 (permalink) Old 05-04-2010, 09:16 PM Thread Starter
farm boy's Avatar
Thanks alot! Looks like ill be calling Kenny again....
farm boy is offline
