whats the best power steering pump for the 7.3? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 01-28-2008, 06:12 PM Thread Starter
i will be running 37's again, and i want something that will turn them esaily.
PMRCM#1
slowleak is offline
post #2 of 19 (permalink) Old 01-28-2008, 06:24 PM
<----Colin Banks
mattymx's Avatar
Re: whats the best power steering pump for the 7.3?
This is the best option for turning larger tires and not killing the power steering box.
http://www.offroadunlimited.com/orus...idCategory=174
mattymx is offline
post #3 of 19 (permalink) Old 01-28-2008, 08:47 PM Thread Starter
holy sh!t!! i think i will pass. is there any upgraded pumps you can buy? i cant justify spending $1200 on power steering, plus the factory pump needs to be replaced
PMRCM#1
slowleak is offline
post #4 of 19 (permalink) Old 01-28-2008, 08:50 PM
<----Colin Banks
mattymx's Avatar
I know it is expensive. But it is made to be able to turn 44+ inch tires while standing still. It takes all the load off the PS pump.
mattymx is offline
post #5 of 19 (permalink) Old 01-28-2008, 09:19 PM
you must have other problems, I've had 2 powerstroke's with 37" or larger tires and had no problem turning them even sitting still. I read a good article about flushing the fluid and refilling with synthetic. I haven't tried it on my truck but it works on the Volvo cars I work on
platinum01 is offline
post #6 of 19 (permalink) Old 01-29-2008, 12:49 AM
tkdbf350's Avatar
Also illegal for street use in California. At least thats what the CHP told us when we put it on my buddy's Blazer. God I hate this state.
2006 F350 CC/LB Lariat FX4, MBRP 4in
2003 F350 standard cab DRW 6spd FX4, aFeII, straight piped duals, DP Tuner Stock, 60T, 80E, 140 Agg, BDP 160cc singles, SBC, ISSPRO A-Pillar gauges boost and egt, ITP Overboost Annihilator, 1.00 Ex. Housing, Wicked Wheel, ITP Pre-pump/In-tank Kit, A/C valve, coolant filter.SOLD
tkdbf350 is offline
post #7 of 19 (permalink) Old 01-29-2008, 12:51 AM
2nd class citizen
1snotrocket's Avatar
another person on this forum threw this web site up you can try their ford replacement pump.http://www.agrperformance.com/products.php?cat=101
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #8 of 19 (permalink) Old 01-29-2008, 12:54 AM
tkdbf350's Avatar
Looking at the one from agr, cuz my stock is whining like crazy, it says 97-2002 is that just because the 6oh was offered in 2003 or will it not fit a 2003 7.3? What do you guys think?
tkdbf350 is offline
post #9 of 19 (permalink) Old 01-29-2008, 12:54 AM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
That kit is really easy to fab up yourself if you into building your own stuff. The steering box is super easy to pull apart and drill and tap the two holes.
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #10 of 19 (permalink) Old 01-29-2008, 01:36 AM
2nd class citizen
there pump should work on 2003 7.3 2002 is the same mounts and lines.
