Drop Track Bar bracket, early 99 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 04-25-2010, 11:23 PM Thread Starter
99whitePSD's Avatar
I have 4.5" lift and have an adjustable track bar(for an early 99) coming but it also looks like i'll need a drop track bar bracket because my drop pitman arm looks like it's going to hit the factory track bar bracket.
What needs to be done to run a late 99-04 Drop track bar bracket on my early 99 with an early 99 adj. track bar? Thanks a bunch guys
99 F350 DRW CCLB 4x4-e99 suspension, 99.5 engine. dp tuner 40t, 60t, 80e, 140e, banks 4" exhaust, big head wga, 6637, boost egt trans gauges, 08 tt mirrors, 02-04 headlights
99whitePSD is offline
post #2 of 10 (permalink) Old 04-25-2010, 11:53 PM
<---new toy
DPS0925's Avatar
Re: Drop Track Bar bracket, early 99
on a four inch lift, you shouldn't have to have a drop pitman arm. just a spacer for the track bar, or an adjustable track bar. I don't think you need both, unless you are going higher.
DPS0925 is offline
post #3 of 10 (permalink) Old 04-26-2010, 12:41 AM Thread Starter
99whitePSD's Avatar
Don't think i'll be going higher(anytime soon anyways). Already have the pitman arm on so i doubt i could return it.
So you're saying you would've just done an adjustable track bar and leave it be? Wish i hadn't have already put the pitman arm on now...
post #4 of 10 (permalink) Old 04-26-2010, 01:18 PM
squeak12's Avatar
I'm pretty sure you need a pitman arm on a 4". A 4" and 6" use the same pitman arm, though.
2001 F-250 Crew Cab 4x4
squeak12 is offline
post #5 of 10 (permalink) Old 04-26-2010, 04:11 PM Thread Starter
99whitePSD's Avatar
I believe i do also because the drag link was at a pretty steep angle with out the drop pitman arm. I ended up finding a drop track bar bracket that actually comes with extended sway bar links so i should be set now.
squeak12-Is your truck lifted 4 or 6"? What track bar/pitman arm set up do you have? Thanks
post #6 of 10 (permalink) Old 04-26-2010, 04:34 PM
jlau6888's Avatar
A 4" lift shouldnt "need" a drop pitman arm. Also with that size lift most use either an adjustable track bar or a track bar drop bracket. Both compensate for the length. Depending on the manufacturer, the adjustable track bar may be too long if used with the drop bracket on a 4" lift.
Jimmy
Early '99 (8/98) F350 CC LB, 7.3 PSD, 4x4, ZF6, 3.73, aFe Stage 2
jlau6888 is offline
post #7 of 10 (permalink) Old 04-26-2010, 05:15 PM Thread Starter
99whitePSD's Avatar
Thanks, so basically i'll need one or the other. Looks like i'll have both so i'll probably use the stock track bar with the drop bracket, if ya'll think that'll be close enough. I guess i'll just keep the adj track bar incase i want to go higher in the future.
post #8 of 10 (permalink) Old 04-26-2010, 05:25 PM
squeak12's Avatar
I have a 4". I had 6.5" and didn't swap the pitman arm over when lowering it since they were the same. The pitman arm is whatever comes with a ProComp lift.
As far as the track bar, I have the drop bracket supplied with the kit not a adjustable bar.
squeak12 is offline
post #9 of 10 (permalink) Old 04-26-2010, 05:28 PM
To be sure..leave the top end of the track bar off..drive 20' back then forward to allow the axle to center..check by measureing. Then see if the track bar will go in the top mount bolted without having to shift the axle over. If not you need to try the adj track bar..some will adjust correctly.
email:
Website:
OBSWIZ is offline
post #10 of 10 (permalink) Old 04-26-2010, 06:33 PM Thread Starter
99whitePSD's Avatar
Thanks guys i'll see how close it is with the drop bracket and factory track bar, if i have to do a lot of work to try to get it on i'll put the adjustable on and center the axle accordingly. Thanks for all the input.
