Problems w/IssPro EV trans temp gauge - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 04-19-2010, 12:02 AM Thread Starter
edge186's Avatar
my trans temp gauge has a wiring issue. the needle constantly jumps around. if i drive over a bump for example the needle will bounce around. also, after sitting all night i started it this morning and it was at 190. this problem didn't occur until a couple months after installing the gauge. it worked perfectly for a while.
i think its an interference problem with other wires but i've already tried to isolate the wires the best i can as well as secure them better.
any suggestions?
2001 F-250 PSD 4x4 Lariat CC SB Auto
Power Hungry Performance
Edge CTS Insight
ATS 4" Straight Pipe
ATS Ported Compressor Housing
AFE Stage II Intake
DI Stainless Up-Pipes
BTS Valve Body
6.0 Billet Converter
6.0 32 Row Trans Cooler
Foil Delete
AIH Delete
CCV Mod
Firestone Ride-Rite airbags
edge186 is offline
post #2 of 11 (permalink) Old 04-19-2010, 12:12 AM
Crazy Redneck
UNCOOL's Avatar
Re: Problems w/IssPro EV trans temp gauge
Sounds like a ground problem. I would try regrounding the gauge and see if that helps.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #3 of 11 (permalink) Old 04-19-2010, 12:14 AM
just a welding fool.
Hawker's Avatar
same here. i noticed after bumping the white "sending" box under the dash a couple times, it would go back to normal. any time i have the issue, i do that, only because i haven't had the time to go searching for what wire it might be.
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
post #4 of 11 (permalink) Old 04-19-2010, 01:10 AM
riverjet
I had 16 ISSPRO gauges with the amplifier boxes. Not one ever worked rite for long.I loved their look so I took a big risk and went to the new performax gauges(American made) and have not had any problems.I could not recomend their older gauges to anyone.Do a Google search.....lots and lots of problems with their older gauges.I could recomend their new gauges.
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
post #5 of 11 (permalink) Old 04-19-2010, 01:13 AM
BRING DA AMBALAMPS
stroke of luck's Avatar
HA...I'm having the same problem. I've been on the phone with Isspro several times and I'm supposed to talk with their test engineer tomorrow. I've run some resistance tests on the gauge and amp box and they both seem mostly ok. I've redone my grounds and power source wiring, tested the sending unit as well. I took video yesterday, I'll try to post it up. There is a 1 yr warranty fwiw...
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #6 of 11 (permalink) Old 04-19-2010, 01:37 AM
BRING DA AMBALAMPS
Here's a couple of vids. Is this what yours is doing?
Sorry for the crappy quality and music on the first. I was backing out of the driveway when it went nuts so I just grabbed my camera and tried to record and back up at the same time
post #7 of 11 (permalink) Old 04-19-2010, 02:40 AM Thread Starter
edge186's Avatar
yeah thats exactly what mine does.
i went back out a minute ago and tried fixing it again. this time i put wire loom around as much of the wire as i could reach under the dash and all the way from the firewall down to the sender. then i secured it better with zip ties to non electrical things as much as i could. i took it for a 15 minute drive just now and it got up to about 140 degrees with no jumping. we'll see how long it lasts this time.
yeah i looked into performax gauges not long ago and they look nice but i don't like the idea of having to buy a electronic signal processor for an additional $300. that puts the total cost up to like $600 or so
Edge CTS Insight
AFE Stage II Intake
BTS Valve Body
Foil Delete
AIH Delete
CCV Mod
edge186 is offline
post #8 of 11 (permalink) Old 04-22-2010, 12:41 AM
BRING DA AMBALAMPS
fwiw...i received a new amplifier box from isspro today. seems to have done the trick!
post #9 of 11 (permalink) Old 04-22-2010, 04:28 AM Thread Starter
edge186's Avatar
did they charge you for it?
Edge CTS Insight
AFE Stage II Intake
BTS Valve Body
Foil Delete
AIH Delete
CCV Mod
edge186 is offline
post #10 of 11 (permalink) Old 04-22-2010, 12:40 PM
BRING DA AMBALAMPS
nope....pm sent
