Homemade Mini-Spring Pack Leveling Kit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 62 (permalink) Old 04-16-2010, 07:17 PM Thread Starter
brettdacosta's Avatar
Hey guys. Had this idea after hearing so many people bad-mouth the use of the mini-spring packs on ebay. But there's not much to these, and if some of them aren't even made of spring steel (if someone could explain the difference to me, I'd really appreciate it), what's stopping me from throwing some plates together drilling a hole through them, and slapping them under my spring? So I'm looking for reasons and answers to the following questions.
Is there any support added to the existing leafs by going with some official DR pack as opposed to an ebay spring pack? Do the ebay types (plate steel from what I've heard) have any arch to them at all? If not, and I could fab some up on my own, what thickness steel do they utilize? Thanks in advance. And to please all the professionals out there, the $100 saved from building them myself would be put towards an adjustable track bar. Looking forward to the info in the professionally done VS. home made spring pack debate that is to come.
brettdacosta is offline
post #2 of 62 (permalink) Old 04-16-2010, 07:42 PM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: Homemade Mini-Spring Pack Leveling Kit
im interested to, if they could save me money by helping me assemble a set of my own id for sure end up spending the 100$ elsewhere with a sponsor here, after u guys got me started modifying my pickup farther than i already had it became an addiciton, now i wana build a race truck
Fordfreak4life is offline
post #3 of 62 (permalink) Old 04-16-2010, 07:57 PM
dadozer's Avatar
In utah it is illegal to put a block in the front butt stacking metal to look like a taller leaf peal is legal it would be the same as putting a bock in the rear.i built my own just using flat steel anit worked great, all you need is steel new center bolt and u bolts.
dadozer is offline
post #4 of 62 (permalink) Old 04-16-2010, 07:58 PM
Mooring Product's Avatar
I don't see why you couldn't.
Pete
2003 F250 FX4 Lariat Crew Cab
No Spray, No Lay...
Custom tuned and sponsored by GoGo Diesel.
Speed never killed anyone; suddenly becoming stationary... that's what gets you. Jeremy Clarkson. Top Gear.
Mooring Product is offline
post #5 of 62 (permalink) Old 04-16-2010, 09:11 PM
Haters Gonna Hate
so you its not necessary to use spring steel? cuz i have some junk spring packs i could cut up, but if i can just use flat steel ill go that route, we have a machine shop next door
post #6 of 62 (permalink) Old 04-17-2010, 12:50 AM
dadozer's Avatar
i measured the gap between the top of the tire and the fender directly above, on my truck there was a 3" gap so i built a stack of cold steel that was the same width as the spring and cut them 1.5 inches longer than the one below it, depending on the thickness of steel you can get and the amount of sag in the front is how many peices you need. i drilled a hole through the center of them for the centering pin using a drill press, trust me drill press is the only way to go dont try drilling using a hand drill you will be there for hours! Then all you need is new center bolts and U-bolts. the nice thing about all of this is that the shock is mounted above the leaf springs and the distance between the that and the shock mount will not change, so you will not need to buy new shocks. lifting your truck this way will not change the ride of your truck becuase the spring rate will stay the same, using an add-a-leaf will arch your springs more and cause it to ride a little stiffer, how much? i dont know. but i did not have to get a longer track bar but i would recommend getting an adjustable one so that the truck tracks straight down the road. not having one will pull your axle more toward the passenger side of the truck and will make it dog track but its not noticeable. i was in the whole project minus the track bar less than 100 dollars little cheaper than buying but more fun to build!
2003 F350 7.3L CCLB 190k
29.5 lpm injectors, MBRP 4" turbo back exhaust, Tunes by Matt from Gearhead! WW, DIY intake w/ 6637 filter, leveling kit, Autometer guages
dadozer is offline
post #7 of 62 (permalink) Old 04-17-2010, 01:56 AM
Lost Cause
Betaracer's Avatar
The key difference between a block and a mini spring pack is the way they are mounted. A mini pack is bolted to the main leaf pack before the whole assembly is bolted together with u-bolts. A block is only held in place the locating pins and the u-bolts.
2016 F-350, FX4, CCLB, 6.7PSD, 7" OUO/ICON/FOX lift, 38x13.50-18 Toyo MT
Betaracer is offline
post #8 of 62 (permalink) Old 04-18-2010, 12:50 AM
i have a 2.5 in leveling kit on my truck i just added a solid steel 1 1/2 in. steel block to get a total of 4inchs of lift the block is welded to the axle
99.5 F-250 X-CAB SHORTBED 4X4
Dyno proven tuning
suncoast tranny
P.I.S 238CC/200% hybrids
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
CUMMINS_KILLA99 is offline
post #9 of 62 (permalink) Old 04-19-2010, 02:52 PM Thread Starter
Hey guys - thanks for the response so far. I posted this thread on a couple other forums, and apparently they're a little more "by the book" then guys around here. I honestly haven't seen too much pointing out there would be anything wrong with this, so I'm willing to consider it a little more.
dadozer - what size plate steel did you use? How long was the smallest leaf that you cut? Just wondering what caused the price to be that much... you said close to $100 - that's about what the maxx-lift ones are on ebay?
post #10 of 62 (permalink) Old 04-19-2010, 03:03 PM
TRUBBS's Avatar
you got any pictures of your diy level kit?
TRUBBS is offline
