anyone have problems with their autometer pyro? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 42 (permalink) Old 01-24-2008, 05:04 PM Thread Starter
mine crapped out i geuss. the needle jumps all over the place. damn electrical gauges. good thing i hade a spare pyro. anyone know a fix for this? also, is it possible for a thermocouple to go out?
PMRCM#1
slowleak is offline
post #2 of 42 (permalink) Old 01-24-2008, 05:51 PM
Bigfoot is an OBS
cowboy_dan's Avatar
Re: anyone have problems with their autometer pyro?
A guy on TDS had the same symptoms, ended up he had an intermittent ground where the thermocouple wire had chaffed.
A thermocouple is a really simple device. It's a pair of dissimilar wires connected (ususally twisted together & soldered) at one end. They produce a very small current when the connection area is heated. The pyrometer gauge is calibrated to amplify the electrical current to a level high enough to move the needle the correct amount.
Go ARMY!
cowboy_dan is offline
post #3 of 42 (permalink) Old 01-24-2008, 06:18 PM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Call Autometer they will probably send you a new probe. I had issues with mine not reading correctly and they sent me a new design and it fixed the problem. I believe it was some sort of ground issue.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #4 of 42 (permalink) Old 01-25-2008, 03:12 AM
i too am having issues with my autometer pyro the needle sticks,then i thump the face of the gauge and it reads
00 ext.cab psd 4x4 14" leaf lift dual fabtech 2.25 all around,40" open countrys on 20" weld race cheyenne 4.88s,warn premiums, 4" banks chopped at rear axle.,DP-tuner. gauges, afe stg 2,ATS trans/TC/flex plate,lock-up controller[SIGPIC][/SIGPIC]train horns
14"stroke is offline
post #5 of 42 (permalink) Old 01-25-2008, 03:17 AM Thread Starter
for a while thumping the gauge on the face would work, then that stopped working too. i ended up taking the gauge and thermocouple out and replacing it with some older stuff. i believe it is a bad thermocouple. i will call autometer tommorrow and see what they say.
and for those who are wondering, i unplugged the autometer gauge and ran the autometer thermocouple to a diprocol. it would not read. when i put in the thermocouple from the diprocol gauge, the diprocol gauge worked, so i stuck it in there instead.
PMRCM#1
slowleak is offline
post #6 of 42 (permalink) Old 01-25-2008, 01:44 PM
The Mule
NWSUPRD's Avatar
Are they lifetime warranty? Mine died and I replaced with something else but would be nice to have the Autometer replaced to I could sell it. I have the bad gauge still sitting on the bench. I was going to disect it and try to see what went wrong. Same symptoms.
1999.5 F250 PSD 4X4
1/8th mile 8.436 @80.21 mph, 1.848 60ft
[SIGPIC][/SIGPIC]
NWSUPRD is offline
post #7 of 42 (permalink) Old 01-25-2008, 03:19 PM
OBS junkie
Cat_Rebel's Avatar
Never had a problem with all the ones I've delt with....
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 42 (permalink) Old 01-25-2008, 07:37 PM
ASTRO's Avatar
Nope ! But my autometer tanny temp gauge doesn`t work. Never has !
MY 2002 f250 4x4 larait crew cab short bed. 12.5" Icon lift w/ OneUpOffroad 5" traction bar block system. Mickey thompso 38X15.50R18 tires on Weld Dune 8 18x10 wheels. Custom pearl silver &purple flame paint, MBRP 4" T-304 SS cool dual exhaust w/ custom made T-304SS flame tips, AFE stage 2intake. Way More!
ASTRO is offline
post #9 of 42 (permalink) Old 01-25-2008, 07:53 PM
Go Away I'm Baitin
fishinfool98's Avatar
Send a message via AIM to fishinfool98
my guage is going corkey now
turn the fan on high it reads 0
turn it too low and it works
hit the window down button and it jumps all around
06 CCLB SRW grey first mod was PSN sticker
Sailors may come
Sailors may go
Tis the engineer below
That makes it Suck, Push, Bang, and Blow
"Closed due to EXPLOSIVE diarrhea, will be back when the EXPLOSIONS are over!"
fishinfool98 is offline
post #10 of 42 (permalink) Old 01-26-2008, 03:41 AM
my Autometer Pyro is just slow..after seeing some vids... it should respond pretty fast... .it doesnt...
Chase
99 S/C shortbox, 7.3, auto, 4wd 315s
4" DP, zoodad, gauge package
TWildman. 6pos. Flipper Chipper, 4" turbo back
A wise man once said; "Nitrous is like a hot chic with a STD..."
"You know you wanna hit it, but you're affraid of the outcome"
Life is like a jar of jalapenos. What you do today, might burn your a$$ tomorrow'.
chasespeed is offline
