CB Killed truck.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-11-2010, 03:21 AM Thread Starter
peterbilt'in
Rob02F350's Avatar
CB Killed truck....
hey yall
so i got my new antenna set up for the redneck internet connection.... and wada you know... driving down the road to get some distance to test it out... key up the mike and the truck f###n SHUTS OFF!!!!!!!!!
key the mike, cuts out. let off fires back up
keep that coax cable away from the ecm... especially after the guy at the cb shop said he spent extra time molesting the guts out of my uniden
anyone else ever have that happen?
2002 F350 extended cab XLT, 4x4 auto,194K mi @ 10/25/13, ELF7405, DP F5, ultra light gauges, all kinds of "improvements" Yukon Grizzly locker 6K helper springs, x code fronts. 2 Y2K jetta Tdi. RC2 tuned
Rob02F350 is offline
post #2 of 12 (permalink) Old 04-11-2010, 01:03 PM
Jeremy's Avatar
Re: CB Killed truck....
I read somewhere its something to do with your F5...but I'm sorry I can't remember what.
16 6.7 F-350 XLT SC 4x4 auto
06 6.0 F-250 XLT SC 4x4 auto
05 6.0 Excursion EB 4x4 auto
00 7.3 F-350 Lariat CC 4x4 12 speed
95 7.3 F-Superduty XL PSD Auto Mechanics Truck
94 7.3 F-Superduty XL PSD 5 Speed 12ft Flatbed
93 7.3 F-Superduty XL IDI 5 Speed 12ft Dump bed
Jeremy is offline
post #3 of 12 (permalink) Old 04-11-2010, 01:06 PM
Don't EFN worry about it
Aljay's Avatar
Never had that happen but I can talk over the am/fm pretty good sometimes.
Tuned by T Wildman
Aljay is offline
post #4 of 12 (permalink) Old 04-11-2010, 01:44 PM
RightWingNut
Tbar's Avatar
Stating the obvious........you have stray RF.
It can be a loose connection, nick in the coax or improperly adjusted antenna causing high SWR's.
Take it to a shop and for a minimal amount they can fix it.
Tbar
Ignore narcissistic trolls.......without an audience they shrivel up and go way.....!!!
Tbar is offline
post #5 of 12 (permalink) Old 04-11-2010, 04:43 PM Thread Starter
peterbilt'in
Rob02F350's Avatar
Tbar
i had to use a 3 foot piece of cable to get just that little extra length, the connector was under the dash, under the computer...
still having a slight issue with the coax connector at the antenna.. cant get the match lower then a 1.4
post #6 of 12 (permalink) Old 04-11-2010, 04:56 PM
ARMY bound
Remove the chip and see if it still happens.
bbbxcursion is offline
post #7 of 12 (permalink) Old 04-11-2010, 06:55 PM
I know nothing...
joedaddy's Avatar
Tbar
Your coax is bleeding!
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #8 of 12 (permalink) Old 04-11-2010, 07:23 PM
OBS junkie
Cat_Rebel's Avatar
Seriously, pull the chip & see if you can run it stock without any CB issues.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #9 of 12 (permalink) Old 04-11-2010, 07:26 PM
Aljay's Avatar
Sounds like you need a good hunk of coax.
Tuned by T Wildman
Aljay is offline
post #10 of 12 (permalink) Old 04-11-2010, 10:43 PM Thread Starter
peterbilt'in
Rob02F350's Avatar
my problem was the connector, to connect the 2 pieces of coax together was right under the computer, along with a few extra feet of wire.... my dumb ass zip tied it down...
re routed the wire, out of the cab via the passengers side, and have had no problems since, well when i cut the ziptie and moved the connector away from the ecm i had to problems, so i just re routed it.
and the coax cable.... Radio shack premium... pos cable... the end nipples are not long enough to fully contact where they need to be but the fix for that.. few drops of solder on the very end.
