single stack-how to? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-08-2010, 12:46 AM Thread Starter
Banned
Well i already have a aftermarket 4" exhaust on but ive always wanted a single black 7" stack in the bed...what im askin is how would i do it? Would i use a flex pipe, cut a hole in the bed and weld it to the bed? Not sure what to do here. Any replies would be great, thanks
Dieselhead Jake is offline
post #2 of 12 (permalink) Old 04-08-2010, 01:08 AM
The Unseen Mod
RescueF250's Avatar
Send a message via AIM to RescueF250
Re: single stack-how to?
Get yourself a 7 inch stack, 5 to 4 adapter, 4 foot flex pipe get a couple band clamps. Contact Grand Rock for the upgraded clamp that bolts to the bed, no need to weld anything, get yourself a 4 inch hole saw to drill your hole from there you run the flex pipe from inside the bed down to your exhaust cut excess flex pipe as you go till you get a good tight fit.
This is how I did my single stack a while back. Wasnt hard at all for me. Less holes in my bed the better, I'll try and take some photos of it when I get a chance.
03 Rescue is Dead
08 Rescue - No Limit Fab, MPD, Rescue Diesel, Barder Turbo, Fuel Lab, H&S products.
RescueF250 is offline
post #3 of 12 (permalink) Old 04-08-2010, 01:08 AM
Clint_FX4_TxBoy's Avatar
weld the stack and 4inch pipe to a plate w/ a hole in it. Cut a 4" hole in the bed. get a pice of 4" flex pipe. drill 4 holes in the plate to mount it to the bed. hope that came out right. the 4" welded on the bottom of the plate will prolly need a 90* at the bottom to then clamp to the flex pipe.
2005 F250 CCSB FX4
Clint_FX4_TxBoy is offline
post #4 of 12 (permalink) Old 04-08-2010, 01:19 AM
squeak12's Avatar
This was my set up with a single 6"
4" flex pipe (12") into a 4" elbow. 4" - 5" adapter with a 5" hole in the bed.
2001 F-250 Crew Cab 4x4
squeak12 is offline
post #5 of 12 (permalink) Old 04-08-2010, 01:26 AM
The Unseen Mod
RescueF250's Avatar
Squeak has the exact same set-up as me. See the clamp around the stack that is the best one you can get and wont break either. U really dont need the 90 cause I dont have that on mine. Either way works good call on the photos Squeak.
03 Rescue is Dead
post #6 of 12 (permalink) Old 04-08-2010, 04:06 AM
"Smoke A Lil Smoke"
chappy's Avatar
curious how much that clamp cost?I have a chrome peterbilt one similar I did on mine cost me $10 bucks at a big rig chrome shop locally.Thats for 5in but they had up to 8in in stock.
2004 f250 egr delete,studded,fass 95,suncoast convertor,itp RR,Banks intercooler,58v tuned ficm,Powermax turbo,Matts tunes,6in Icon and 35 toyos 20x12 fuels
Early 99 exlb 4wd-SOLD All Shaeffer oil
Will Iott -8/24/84-7/4/10 "We miss you buddy"
chappy is offline
post #7 of 12 (permalink) Old 04-08-2010, 03:15 PM
squeak12's Avatar
I think they are fairly overpriced, but I got all of my stuff used from bigrpower. It was on his burgandy truck.
squeak12 is offline
post #8 of 12 (permalink) Old 04-08-2010, 07:24 PM Thread Starter
Banned
Thanks alot guys, this helped me out alot. Hopefully i can do this soon, maybe this summer. Thanks squeak for the pics and thanks to everyone else with there input!
post #9 of 12 (permalink) Old 04-09-2010, 06:37 PM
hypersnyper694788's Avatar
Besides the price of the stack itself, one could probably do this for pretty dam cheap huh?
06' F-250 CC SRW 4x4, 6" fabtech lift, bilstien 5100 shocks, 4" MBRP TB no cat, ARP studs, 2 JL audio 10" W0, 20x12 weld cheyenne 8's, 35x13.50x20 Mickey Thompson Baja ATZ
BNIB 6.0 head with all related hardware, straight from FORD. For Sale PM me offers
hypersnyper694788 is offline
post #10 of 12 (permalink) Old 05-12-2010, 08:35 PM
WINNING
Countryboy07's Avatar
Yes, I will have about $150 dollars in mine that is including the stack. The way I am going to do it is to have a flat plate with a piece of 4" going down throw the bed and then a piece of 5" going up to the inlet of the stack. 4 holes in each corner of the plate and bolt her down to the bed. No need for a clamp and it is easy to remove the stack when not in use.
-French
2002 VW Jetta TDI
Countryboy07 is offline
