Question about Autometer GS gauges - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-31-2010, 11:16 PM Thread Starter
I installed my Pyro and boost gauges on sunday and love 'em! However, those green LED's are super bright! like green spotlights! I have them tapped in to my dimmer so they dim w/ the dash lights but are still bright! I was wondering if I could tap a resistor in-line to them on the illumination wire to dim them down just a hair? I would think so.... and if so, what size resistor? My Ohm's law training is escaping me right now!!!!!! Need a refresher/guidance. And if it can't be done, oh well. Just an idea.
-Ryan
-Ryan
2004 CC SB 6.0L, T/S, red, FX4, XLT, Autometer GS Pyro and boost gauges. SCT Xcal2...tunes from Matt @ Gearhead Automotive
browtine is offline
post #2 of 12 (permalink) Old 04-01-2010, 12:32 AM
-Adam
fahchoda's Avatar
Re: Question about Autometer GS gauges
You can use resistors, and it works great. The challenge is trying to find out what resistors to use. Autometer also sales a dimmer just for this.
Auto Meter
Why don't you post some pics. I would like to see how it turned out. I am planing on the same guages on my 04.
fahchoda is offline
post #3 of 12 (permalink) Old 04-01-2010, 01:11 AM
HP Junky
I love my GS gauges, nice look to them, but a dimmer is needed for sure.
RockinJW is offline
post #4 of 12 (permalink) Old 04-01-2010, 01:17 AM
Canadian Stroker
doubledoor's Avatar
If you find a headlight switch out of a car that dims when you turn the knob. You can wire it inline and adjust it to your liking.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #5 of 12 (permalink) Old 04-01-2010, 01:21 AM
doesnt autometer sell a dimmer.........
yep they do, pure diesel power has them and Im sure other vendors sell them
02 f250
countryboyrob is offline
post #6 of 12 (permalink) Old 04-01-2010, 01:49 AM Thread Starter
So my question now is: If I wire a dimmer in line, or any potentiometer or rheostat i guess, that's just in-line and will alter the signal given from my factory dimmer? So that even with something in line, it will still dim and brighten via my factory dimmer? once I've dialed in the one that's "in-line" which will basically just change the brightness ratio from dash lights to pillar gauges.... in a sense.... or in lamen's terms
-Ryan
browtine is offline
post #7 of 12 (permalink) Old 04-01-2010, 01:50 AM Thread Starter
I've gotta get an avatar..........
-Ryan
browtine is offline
post #8 of 12 (permalink) Old 04-01-2010, 01:52 AM
if you wire the dimmer inline with the hot wire that powers the lights and the lights them self they will dim and not the dash lights.
basically putting the dimmer between the lights and the factory light switch
post #9 of 12 (permalink) Old 04-01-2010, 02:14 AM Thread Starter
I guess I dont understand. They dim with the dash lights now, so if I put an additional resistance in line between where they (gauge lights) are powered from now, and the gauges themself, why wouldnt they still dim with the factory dimmer? I'll just have to try it and see. Everyone's ideas have definitely got my thinking cap on now.
-Ryan
browtine is offline
post #10 of 12 (permalink) Old 04-01-2010, 02:40 AM
-Adam
fahchoda's Avatar
If you put the additional dimmer between your hot wire, and your guages you will have the effect you want. Your guages will still dim with the dash lights, but you will be able to dial in the guages, and get them to match the brightness of your dash.
fahchoda is offline
