Brakes refuse to bleed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-28-2010, 10:20 PM Thread Starter
OBS junkie
Cat_Rebel's Avatar
Posting this for a friend of mine- (means I'm not there to see it or work on it myself)
Truck is a late 99 350, that has brakes that will not bleed. Tried pumping them, old fashion gravity bleed, & so on. Got alot of air out of it but the pedal is still useless. I know the SD doesn't have an ABS module like the OBS does. What's left after that, master cylinder?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #2 of 9 (permalink) Old 03-28-2010, 10:23 PM
PSN Pretender
907DAVE's Avatar
Re: Brakes refuse to bleed
Try bleeding it right at the master cylinder to see if it will even move fluid through it...........
907DAVE is offline
post #3 of 9 (permalink) Old 03-28-2010, 10:35 PM Thread Starter
OBS junkie
Cat_Rebel's Avatar
You talking about pulling the lines off, letting it bleed out then re attaching them?
RIP Will Iott
post #4 of 9 (permalink) Old 03-28-2010, 10:40 PM
madmaxz's Avatar
pump the brake, hold, loosen the hard lines one at a time at the master see if fluid comes out
Rick
2002 F250 CC LB - 5" lift, BTS, 4.10s+trutrac, 250/100s, studs, pushrods, dual springs, ITP RR, 2 SD pumps, Beans plenums, Balanced, Blueprinted and cryod bottom, ported heads, GH 1.5 cam, 4" Exhaust, 6.0 trans cooler
OTW- S366/s483 compounds, 20x10 black hostages + 37 13.50 toyos, fresh BTS, Live tuning, And maybe an srp 1.1
madmaxz is offline
post #5 of 9 (permalink) Old 03-29-2010, 02:54 AM Thread Starter
OBS junkie
Cat_Rebel's Avatar
Problem solved, master was "Fubar". Replaced it & it works fine now.
RIP Will Iott
post #6 of 9 (permalink) Old 03-29-2010, 04:27 AM
PSN Pretender
907DAVE's Avatar
Good deal!
907DAVE is offline
post #7 of 9 (permalink) Old 03-29-2010, 05:23 PM
I am the juggernaut.
SevenThree's Avatar
This was a nightmare, just sayin.
Master was fine when I first tested it, replaced a caliper and the couldn't find a mysterious air pocket.. bled them like 7 million times.. also at the abs mod and the master with no luck then she refused to bleed all together so I tested the master again and no good....
aannnnnnnnnnnd then my front passenger caliper locked up last night
FML.
Will Iott -8/24/84-7/4/10
Chris Owens-4/9/90-3/12/10
99.5 doooley. swamps. murff racing. gearhead.
SevenThree is offline
post #8 of 9 (permalink) Old 03-29-2010, 05:28 PM
PSN Pretender
907DAVE's Avatar
Someone using the wrong fluid?
907DAVE is offline
post #9 of 9 (permalink) Old 03-29-2010, 09:54 PM
SevenThree's Avatar
Dot 3
