Oil coming out of Exhaust - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 12-02-2019, 05:54 PM Thread Starter
I have a 2002 F350 7.3 lariat With 4 inch exhaust a TS6 and that’s about it done to it. I took the old cab off because of body damage put a new cab on And used all the existing wiring out of the old cab Now everything did get separated to take the cap off as far as wiring harness. We did replace the up pipes And a deleted pedestal. Put everything back together cranked it up and after about 15 minutes it blew about a gallon of oilOut of the exhaust so we ordered a new turbo cartridge and replaced it Fired the truck back up noticed it was leaking oil out of the down pipe v clamp then about 10 mins later puked oil back out the Exhaust again like the turbo went out I’m clueless any help would be appreciated thanks
Johnshelor is offline
post #2 of 2 (permalink) Old 12-03-2019, 04:00 PM
alleged moderator
tjctransport's Avatar
Re: Oil coming out of Exhaust
did you replace the o rings on the turbo oil feed?
tom
tjctransport is offline
