DIY: Paintable Grille - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 03-25-2010, 01:07 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
So, I discovered something yesterday.
Before I begin, I want to say, that I take absolutely NO responsibility for any damage you may do to you messing up your grille. To be honest I haven't really done this completely, or even really thought it out.
But here goes.
If you have a chrome grille, and you want to paint it, we all know how much of a PITA it is to get paint to stick to chrome...
Well, here is an option.
First, you'll need,
A razor or exacto knife.
A butane torch, I just took the end off of my portable soldering iron and used that.
LOTS of patients.
I'll tell you how I did it, then I'll try to show you my videos.
First of all, take the grille off of the truck...
Then, turn your torch on, and quickly run it over the chrome. You'll see it bubble up.
Take your razor, and cut a 1" slit into a seam, somewhere you can "mess up", and run the torch over that area quickly. Sometimes, the chrome will curl up, and it makes it easier to grab. And then just start peeling away... It's time consuming, but if you do it right, you'll get the chrome off pretty easy.
The best thing I can tell you, is DO NOT let the chrome get too hot... Once it gets too hot, it'll melt the plastic to the chrome, and it will be TWICE as hard to pull off.
I'll show you some of my mistakes, and some examples the best I can.
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #2 of 18 (permalink) Old 03-25-2010, 01:10 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Re: DIY: C
228-365-0698
post #3 of 18 (permalink) Old 03-25-2010, 01:10 PM
Metal - It kicks your ass
Re: DIY: C
How in the FOOK did you come up with this...? Awesome!!!!
I wanna see vid or pics first though.
Modded L99
dirtboy25 is offline
post #4 of 18 (permalink) Old 03-25-2010, 01:15 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Re: DIY: C
My videos suck. Because I did most of the grille, and sharing was an after thought. But I tried to illustrate the best I could... And I messed the title up, so in case I'm not around, and a mod sees this, I'd like it to read...
"DIY: Chrome Grille to Paintable"
228-365-0698
post #5 of 18 (permalink) Old 03-25-2010, 01:53 PM
Military/Firefighter
MPmedic5's Avatar
Re: DIY: C
thats pretty slick... good idea
MPmedic5
2003 F250 6.0L Diesel 4x4
SCT Livewire
Custom Tunes by Innovative Diesel
EGR Delete
3rd and Hopefully Last Set of HeadGaskets
Hi-Idle Mod
Lights and Siren
Nitto TerraGrapplers
MPmedic5 is offline
post #6 of 18 (permalink) Old 03-25-2010, 03:42 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Re: DIY: C
These are some examples of what will happen if you overheat it... I'm sure if it came down to it, you could smooth most of it, and what you couldn't, you could fill it with some bondo...
228-365-0698
post #7 of 18 (permalink) Old 03-25-2010, 03:49 PM
Re: DIY: C
So, you waste all this time pulling off the chrome, just to have to come back and fill in holes you made with bondo, and then sand, prime and paint plastic which is just as hard to get paint to stick to as chrome? Tripple work, same results...
BUT if one was to do this, I would highly recomend a heat gun...smoother heat and WAAYYY less of a chance of burning the plastic like Jap did.
PMRCM#1
slowleak is offline
post #8 of 18 (permalink) Old 03-25-2010, 03:57 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Re: DIY: C
You could try a heat gun, but I don't think it would work.
Go ahead Mr. Negative. YOU show us how to do it.
228-365-0698
post #9 of 18 (permalink) Old 03-25-2010, 04:07 PM
Re: DIY: C
simple. sand chrome with 320 grit, prime with bulldog, prime with primer, wet sand with 400 (if your anal) re-prime, paint with color, 600 sand, re-paint, clear, 600 wet sand, re-clear and polish.
Every step i listed, would have to be done AFTER you peel the chrome, and fill holes with filler (not bondo cause bondo sucks) the only thing different is, in the first step your sanding chrome, not plastic, and your not taking the risk of melting the plastic
As for the heat gun, it will DEFFINATELY work...but I have no clue what I'm talking about, never worked at a body shop or a sign shop
PMRCM#1
slowleak is offline
post #10 of 18 (permalink) Old 03-25-2010, 04:10 PM Thread Starter
<--Spy Vs. Spy
theSLEEPER's Avatar
Re: DIY: C
OK. So you're going to wet sand with 600... Gotcha.
228-365-0698
