Will signal mirror covers work on old mirrors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 01-20-2008, 10:44 AM Thread Starter
coope3's Avatar
Will the signal covers off a 04-07 truck fit on the older mirrors if I use my own leds for the running and turn signals and how hard are the mirrors to get out and back in a new cover.
02 F350 CC 4x4, Common rail, 90hp injectors, Hellman intercooler,studs,twin cp3s,64/71/14 HTT turbo, HTT manifold,maxspool cam,Smarty POD,TS MP8,ported head, BTS tranny,PCS tranny controller,Airdog,Trac bars
2015 F250 CC 4x4 6.7 powerstroke stock
coope3 is offline
post #2 of 7 (permalink) Old 01-20-2008, 02:39 PM
txpsdcrwchf's Avatar
Send a message via Yahoo to txpsdcrwchf
Re: Will signal mirror covers work on old mirrors
the cover is really easy to take off... theres tabs behind the mirror youll have to move the mirror around to realease them... i think theres three... one on the outside.. one on top, and one on the bottom. the covers actually house the led's and reflectors.. sooo you wouldnt have to use your own leds etc...
Jeff
HIS: EARLY '99 F250 SD 4x4 Off Road, 7.3L PSD 6 SPD SuperCab Short Bed
DP Tuned (F5) NS, S, 40T, 80E,
HPx Line-DIY Tymar-Fuel System(on Return)
HERS: '99 DODGE Ram 2500 4x4 5.9l I6 Cummins 6SPD QuadCab Shortbed
Edge ez 20, 40, 60:
txpsdcrwchf is offline
post #3 of 7 (permalink) Old 01-20-2008, 03:32 PM Thread Starter
coope3's Avatar
that sucks then, there was a pair of the signal covers on ebay the other day for 30.00 each
coope3 is offline
post #4 of 7 (permalink) Old 01-21-2008, 03:19 AM
NEVRNF's Avatar
NO, your mirrors do not have a removable cover.
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
post #5 of 7 (permalink) Old 01-21-2008, 03:45 AM
Banned
nope the old tyle 99-02 do not have removable covers. the 03-07 covers are removable.
whiteduallyil is offline
post #6 of 7 (permalink) Old 01-21-2008, 06:53 AM
I stand corrected.... but now that i think about it... ive only ever had to remove the covers on the mirrors that i installed off an 04. Never had a reason to try to open up the others...
Jeff
Edge ez 20, 40, 60:
post #7 of 7 (permalink) Old 01-23-2008, 03:08 AM
ERJ Aircraft Mechanic
Tail_gunner's Avatar
The covers aren't removable??
I guess I shouldn't have taken the driver's side cover off when I had to modify the wide angle mirror to raise its elevation. Been going on 8 years now, and you can't tell it was ever removed and re-installed.
Kent
FAA Certificated Airframe & Powerplant Mechanic
USAF MSgt (Ret.)
B-52 Gunner, 3600+ Hours
B-52 crew chief
SOLD: Early 99 F-250, 99.5 PCM, Single Shot Stage I's, Power Hungry Perf, Dominator 66 Turbo, Adrenaline HPOP, 6.0 Intercooler, Trans by BTS, MBRP 4" exhaust, 99.5+ intake covers, Hutch Mod, KCM H/X, Dynatrac. 0-60 < 7 sec's.
Tail_gunner is offline
