2008 steering wheel in a 2003? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 03-23-2010, 03:20 AM Thread Starter
Banned
Can a 2008 steering wheel work in a 2003 super duty? If so how do you install it? Any help would be great, Thanks.
Dieselhead Jake is offline
post #2 of 2 (permalink) Old 03-23-2010, 04:00 AM
Re: 2008 steering wheel in a 2003?
The wheel should fit right on. You will need the airbag/cover as well. Make sure yo let the airbag back up power drain before removing it. Unplug both batteries and wait several minutes. Then unscrew the airbag from the wheel and then pull the wheel with standard gear puller.
The trickier part is if you plan on using the switches on the wheel. (assuming you have them and its not a XL model). You may find that you have to get a different clockspring and/or do some custom wiring to make things work. Someone on here said the cruise control was a little different as well. I don't know about that. Should all be doable though!
Early 99 (build 04/98) F250 XLT Supercab, 7.3 PSD, 4x4, 4R100, SRW, 6637 DIY intake, 4" TB exhaust, RCD leveling kit, 05 front facelift, 05 tow mirrors, 05 body badging, 05 Dash, Body molding delete, Difuser headlight harness, 20x10 XD Diesels(black), 305/55/20's, Stainless brake lines, Updated PCM, White face gauge overlay, 2002 seats.
Early99PSD is offline
