Compressor ideas... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-20-2010, 06:32 PM Thread Starter
F350 Balla
Send a message via AIM to 4eyedconekiller
Compressor ideas...
I'm looking to add a compressor/tank combo to the F350... The plan is to use it to air up tires, and lightly use some air tools on calls. I found the Warn VTC, but really dont wanna spend 5-600 bucks on a compressor and single gallon tank. The plan is to use a 12V compressor, and source a couple 6-8" diameter air tanks from a semi.
Has anyone ever done anything like this? Any advice you guys you would give?
4eyedconekiller is offline
post #2 of 13 (permalink) Old 03-20-2010, 07:51 PM
Catfish Mafia
li'l tugger's Avatar
Send a message via Yahoo to li'l tugger
Re: Compressor ideas...
i put a viair (sp) in my toolbox. it was a tank/compressor combo. i just seperated the tank from the compressor to make them fit like i wanted. this way, the compressor is out of the weather and no one knows unless they look in the box or get an air horn up their butt!
early 99 cc 4X4.. 4" exhaust, cushtom tunes, DI hybrids, DI tranny, GQSSB turbo and 3" plenums from WOP,
13.94 @ 96.9mph.. on stock turbo
li'l tugger is offline
post #3 of 13 (permalink) Old 03-20-2010, 07:59 PM
Moved in
sagebel's Avatar
I'm running a Viair 460C into a tank I got off of a big truck at the junkyard. Compressor is under the hood where the driver side battery goes. Tank is outside the frame under the rear passenger door.
2011 F250 CC 4x4 Sterling Gray Metallic
2010 Cannondale Quick 4 (pedal powered commuter)
sagebel is offline
post #4 of 13 (permalink) Old 03-20-2010, 08:08 PM Thread Starter
F350 Balla
The Viair stuff looks pretty neat... Any chance that with a big truck tank, I could run a small impact for short periods of time?
I've got a few friends in the lowrider community who might be able to give me a hand with all of it as well. Looking to plumb the tanks together and bring up a quick connect in the bed, and run hoses from there.
post #5 of 13 (permalink) Old 03-20-2010, 08:54 PM
Catfish Mafia
with enough tank capacity, you could run some small tools.. just dont know for how long. the viair fills tanks pretty quickly, so you just have to take it slow with the impact! i am running the oem tank now, but a 7 gallon is going in when i redo it. whatever you do, use soft air hose for the whole plumbing job. i have done it both ways, and the hard lines always leak.
post #6 of 13 (permalink) Old 03-21-2010, 09:25 PM
Lost Cause
Betaracer's Avatar
i'm running a pair of viair 480C compressors mounted outboard to the frame under the cab on the passenger side, and the 3 gallon tank is a little further back, under the bed.
2016 F-350, FX4, CCLB, 6.7PSD, 7" OUO/ICON/FOX lift, 38x13.50-18 Toyo MT
Betaracer is offline
post #7 of 13 (permalink) Old 03-21-2010, 10:15 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
My dad loves his viair system. He's got quick connects front and rear.
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #8 of 13 (permalink) Old 03-22-2010, 04:35 PM Thread Starter
F350 Balla
I actually got a KILLER deal on a Viair setup... A single 480, with a 5 gallon tank and all the plumbing/tubing/fittings that I'll need for less than 100 bucks! I love having friends in the lowrider community, lol.
post #9 of 13 (permalink) Old 03-22-2010, 04:42 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
DAMN!!!!
228-365-0698
post #10 of 13 (permalink) Old 03-22-2010, 07:07 PM
40 lug nuts
Snake's Avatar
I'd recommend against using soft line depending on the pressure you plan on running. 200 psi through soft lines isn't generally a good idea.
BULLETPROOF DIESEL
Biofuels Technologies
1A Auto
2005 F-250
Snake is offline
