35" MICKEY ATZ'S on 20's W/ LEVEL KIT? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-20-2010, 03:45 AM Thread Starter
mbg75's Avatar
Anyone know if i can put 35/12.5/20 atz's on an 2002 with just a level kit?
shows that the tire is actually 34.6" tall. how bad will it hit?
2002 F-250 ccsb, 7.3, Auto, 4x4, BDP Tunes, Stealth Drop In, 4" MBRP, 6637, Van turbo WW ATS, Frantz Bypass,Drilled & Slotted Rotors
mbg75 is offline
post #2 of 13 (permalink) Old 03-20-2010, 05:38 AM
F-25000's Avatar
Re: 35" MICKEY ATZ'S on 20's W/ LEVEL KIT?
depends on backspacing of wheel but plenty of people on here run that set up just fine
2004 F-250 regular cab long box, 6.0 w/ 6 speed, 4" turbo back exhaust, airaid airfilter, SCT, Sinister coolant filter, ARP studs, EGR delete, gauges- sold
2010 F-350 crew cab short bed Lariat. 6.4l with auto trans. Deleted and tuned.
Dylan
F-25000 is offline
post #3 of 13 (permalink) Old 03-20-2010, 06:16 AM
You should be good. I'm running 35's and they will rub a bit but my wheels have a lot of back spacing and stick out about 3-4"
bigjake0524 is offline
post #4 of 13 (permalink) Old 03-20-2010, 02:00 PM
28 cent #2
daryl4412's Avatar
I run 35's on 20's with no problems
daryl4412 is offline
post #5 of 13 (permalink) Old 03-22-2010, 12:24 PM
i am running 35x12.50R18 on stock suspension and i only rub with real hard turns and minimum back spacing.
oopowerstroke4x4 is offline
post #6 of 13 (permalink) Old 03-23-2010, 12:12 AM
i have them on my truck!!! they rub a little bit at full turn but not bad!!
USAF TSGT Retired "Medically"
99.5 CCSB 4x4 built motor and BTS
99.5 EX Cab Long bed with mild mods and BTS
Big thanks to Swamps Diesel and BTS!!!
randylamarr is offline
post #7 of 13 (permalink) Old 03-23-2010, 12:14 AM
Jomax's Avatar
I have them and i just installed a leveling kit for my dually today they rub really little and rubbed less then with no leveling kit. You'll be fine.
2000 F-350 4x4 DRW 200,000 miles DP tuner Stock, 40T, decel, 60T, 80T, 80eco, 120race, ported compressor housing, bellowed up-pipes, Terminator T-500, FPR Spring mod, AIH delete, autometer ford factory match boost, pyro, trans, HPX crossover tube, AFE Stage II CAI, 5in Straight pipe, JW valve body, Deep transmission Pan with magnet
Jomax is offline
post #8 of 13 (permalink) Old 03-23-2010, 01:51 AM Thread Starter
mbg75's Avatar
thanks for the info guys. really leaning towards 35's. 33's just look like not alot of sidewall on 20's. can you guys post up some pics?
mbg75 is offline
post #9 of 13 (permalink) Old 03-23-2010, 02:55 AM
Junior Mint
Is this a good tire? Noise, wear, traction, wet weather performance, off-road traction, snow traction?
Considering these as replacements for my Nittos.
Thanks.
I'm officially...Stroke-less.
Suns_PSD is offline
post #10 of 13 (permalink) Old 03-23-2010, 04:27 AM
I luv the atz's. IMO, they are great all around tires.
Early 99 (build 04/98) F250 XLT Supercab, 7.3 PSD, 4x4, 4R100, SRW, 6637 DIY intake, 4" TB exhaust, RCD leveling kit, 05 front facelift, 05 tow mirrors, 05 body badging, 05 Dash, Body molding delete, Difuser headlight harness, 20x10 XD Diesels(black), 305/55/20's, Stainless brake lines, Updated PCM, White face gauge overlay, 2002 seats.
Early99PSD is offline
