how to connect a 4" down pipe - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 03-19-2010, 01:45 AM Thread Starter
winkfab's Avatar
How do you connect a 4" down pipe (turbo down)to the stock exhaust, just a reducer. Its going on my cousins 2000 f350
Wink Fab - cnc machining and fabrication
2008 f250 4x4 bone stock and ready to mod/repair
97 f350 4x4 410 gears 37 BFG, 4" exhaust, dyi, tw chip,
IDM mod, .427 sonnex valve, rsk w/sd springs, grease able 4x4 lever,Rosewood stage 2, T-500 hpop,1.0 ex housing
These trucks are like crack, you just can't leave it alone.
winkfab is offline
post #2 of 16 (permalink) Old 03-19-2010, 02:02 AM
Re: how to connect a 4" down pipe
Just reduce it may have to do some cutting and welding. May need to get a flange to connect to the turbo.
bigjake0524 is offline
post #3 of 16 (permalink) Old 03-19-2010, 02:06 AM Thread Starter
winkfab's Avatar
I thought since they sell just the down pipe and a muffler delete they would sell a reducer so you can do a weekend bolt on.
winkfab is offline
post #4 of 16 (permalink) Old 03-19-2010, 02:17 AM
It may come ready to bolt in if it's for you're application!
post #5 of 16 (permalink) Old 03-19-2010, 02:19 AM
If you buy it per application it will bolt in. to remove the stock one i had to cut the end of it off. Will be the same for your truck. Mine is a 2000.
rbwhat377 is offline
post #6 of 16 (permalink) Old 03-19-2010, 04:00 AM
tbolt's Avatar
The orig is too long to clear the cross member. My Diamondeye was short enough to go right in with no trouble. You can get a 4" turbo back sys with all new 4" for less than $300. Just do it all.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #7 of 16 (permalink) Old 03-19-2010, 04:25 AM
OBS junkie
Cat_Rebel's Avatar
Why would you go from a 4" DP to a 3" stock exhaust?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #8 of 16 (permalink) Old 03-19-2010, 04:59 AM
<---- Funny
wriott's Avatar
Will
2002 F-350 CC LB 4x4 DRW
3 other PSDs, Low-Pro Freightliner, and 12 other diesel trucks
Random pics
wriott is offline
post #9 of 16 (permalink) Old 03-19-2010, 12:15 PM
Diesel Huffer
SoCalPowerStroke's Avatar
x2. just put my 4 in dp in yesterday, took all of 30 mins doing it myself, easiest way to get the stocker out is to cut it infront of the trans cross member and take it out, hardest part is just getting the vband clamp on right.
08 F250 ccsb 4x4, retro 4300k hids, mini maxx (hot damn tunes) 4in dpf delete to 7in single stack, s&b intake kit, ptp egr delete. (wheels and tires with leveling kit coming soon)
E99 F-350,modded and sold
03 6.leaker modded and sold
SoCalPowerStroke is offline
post #10 of 16 (permalink) Old 03-19-2010, 02:11 PM
wheres the fat chicks?
PowerstrokeR00's Avatar
yea....the down pipe install and tear out is pretty easy on a 7.3
2000 F-350 SD ccsb=185hp
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
4in straight pipe=50hp
Custom Fuel system w/ sump=50hp
Foil,AIH,EBPV delete=30hp
Wow...I'm making 500hp
Originally Posted by stroke of luck View Post
i started sharting at an early age...
PowerstrokeR00 is offline
