Tire Questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 01-18-2008, 12:45 AM Thread Starter
Soon to be a 6.4
lildevil02's Avatar
Send a message via AIM to lildevil02
Tire Questions
I'm going back to stock wheel for a bit while the new motor is being built. I want to find the widest A/T tire that can be mount on stock 99 wheels. I want a good tire that will last a while and wear good. I was looking at ProComps A/T in 305/70/16. Anyone else know of a good brand thats wider?
On edit: I just found MT ATZ 375/55/16...? would that fit on stock wheels, seems kinda wide for the wheels.
lildevil02 is offline
post #2 of 12 (permalink) Old 01-18-2008, 12:52 AM
Diesel Freak's Avatar
Re: Tire Questions
ProComps IMO have a softer rubber compound. Great off-road tire but not best wearing tire for street. Look at BFG At.....great wearing tire but pricey!
Toyo has a nice tire also. Hope this helps.
Diesel Freak is offline
post #3 of 12 (permalink) Old 01-18-2008, 01:36 AM Thread Starter
Soon to be a 6.4
lildevil02's Avatar
Re: Tire Questions
Yea I have BFG but would like somthing I bit wider..If I cant find anything I'll stock with BFG.
post #4 of 12 (permalink) Old 01-18-2008, 01:55 AM
Oooo, White Lightning !
Dieselboy's Avatar
Re: Tire Questions
I was gonna say check out the MT ATZ.....I think 15.5 would be pushing it.....The biggest Id go on stock rims is a 12.5-13 Your rim is only 8" wide
You could put it on there but you would have alot of buldge
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #5 of 12 (permalink) Old 01-18-2008, 03:23 AM
Really?
pwrstrk4x4's Avatar
Send a message via Skype™ to pwrstrk4x4
Re: Tire Questions
The general rule is that you don't want to put on tires that are more than 4 inches (sidewall) wider than your wheel. I'm curious. Are your stock wheels 8 inches wide? The ones on my 06 were 7.5".
2006 Ford PSD FX4 Lariat CC/SB AT
33"x13.50" Pro Comp XTerrains on Helo 837 18"x9"
5" straight pipe to 48" long 8" slash cut single stack
Everything else stock.
There is a mysterious bond between man and machine.
pwrstrk4x4 is offline
post #6 of 12 (permalink) Old 01-18-2008, 03:50 AM
bigd4me2's Avatar
Re: Tire Questions
outside dimension is 8 inch lip to lip but, inside dimension is 7.5, rim is stamped 8 inch. is that the same as yours?
02 dmax cc dually 4wd "miss piggy" tow bitch, afe pr7, magnaflow, Kennedy lift pump, dual rail mount filters, PPE tunes
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges, dual rail mount filters
bigd4me2 is offline
post #7 of 12 (permalink) Old 01-18-2008, 04:14 AM
Evil Genius
DCSpecial's Avatar
Re: Tire Questions
99-04 16s were 16x7
04 HDs had 18x8
05-07 are 17x7.5, 18x8 and 20x8
That being said....a 375mm is waaaaayyyy too wide for a 16x7 wheel.
Based on tire rec. specs...a 285 is about as wide as you want to go on a 7" wide wheel
Some guys do go 295 or 305 without issue though.
DCSpecial is offline
post #8 of 12 (permalink) Old 01-18-2008, 09:09 AM
BUFF's Avatar
Re: Tire Questions
Had 305 70 r16 on the stock steel wheels on my old 02 thay fit nice my buddy was running the same size on his excursion with the limited wheels.
06 F350 CC LB 4x4 with a few odds and ends
BUFF is offline
post #9 of 12 (permalink) Old 01-18-2008, 02:10 PM Thread Starter
Soon to be a 6.4
lildevil02's Avatar
Re: Tire Questions
I ran 315/75/16 for about 2 year without an issuse. So if I want to go up to 375/55/16 I need a wider wheel right?
post #10 of 12 (permalink) Old 01-18-2008, 10:12 PM
Evil Genius
DCSpecial's Avatar
Re: Tire Questions
Yes, you need a 10" wide wheel for that at least.
375mm= ~14.76" wide.
