Question about train horns - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 03-15-2010, 07:44 PM Thread Starter
REDSOX2758's Avatar
Ok, just got me some train horns from hornblasters but I dont know where to mount the tank? Does the drain valve on it have to point down? Any pics would be great, Thanks!
2004 F-250 6.0
117,XXX miles
05 front end conversion
Innovative's SCT tunes
ISSPRO EV LED gauges
7 inch single... straight piped
3 inch lift
18X9 XD Series Hoss
35" Toyo m/t's
Train horns
5% Tint
Best 1/4 - 13.96 at 95.46 MPH
REDSOX2758 is offline
post #2 of 15 (permalink) Old 03-15-2010, 07:49 PM
A Ghost these days...
farm boy's Avatar
Re: Question about train horns
How large is the tank? You should be able to mount it to the outside of the passengers side frame rail. I had 2 tanks mounted there on my old SD. (1) 7 gallon, and (1) 5 gallon.
There is this damn thing called gravity, so I dont think the water that forms in your tank from condensation is gonna flow out if the drain valve if its pointing upward. Sorry, I had to.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #3 of 15 (permalink) Old 03-15-2010, 09:42 PM Thread Starter
REDSOX2758's Avatar
I guess that does sound dumb after reading it. I just didnt know if you drained it when there was air in the tank that it would push the water out??? Guess not. Its only a two gallon tank but the brackets on the tank are pointed straight up or down....so if I were to mount using the existing brackets the drain valve would be pointed sideways....
2004 F-250 6.0
117,XXX miles
3 inch lift
18X9 XD Series Hoss
35" Toyo m/t's
Train horns
5% Tint
post #4 of 15 (permalink) Old 03-15-2010, 09:59 PM
farm boy's Avatar
Do you have access to a welder / fab tools? I would make a new bracket that would bolt to the frame and come outwards. Then, bolt the tank hanging from that.
farm boy is offline
post #5 of 15 (permalink) Old 03-15-2010, 10:23 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
My setup...
Joe
CSIPSD is offline
post #6 of 15 (permalink) Old 03-15-2010, 10:32 PM
PSDnate's Avatar
This is my setup from hornblasters. I have a 2 gal. tank. Everything is mounted to a steel plate and that mounts up where the spare tire goes.
2004 f350 6.0L psd 4x4 6spd cc sb dark shadow gray, sct tuned by eric, 6" ICON 20x12 centerline, 35x13.5 mickey t atz
PSDnate is offline
post #7 of 15 (permalink) Old 03-15-2010, 10:38 PM
<---- my shop
vader's fury's Avatar
I had my tank mounted where the spare was. was a 5 gal tank though...... My horns are mounted on either side of the cab right behind the front wheel wells makes is invisible but also very loud to whoever is in front of me and needs to move. Having emergency horns doesn't hurt either
Robert
2003 F-350 CCLB, 7.3, Auto
2000 F-450 Sold.....
vader's fury is offline
post #8 of 15 (permalink) Old 03-15-2010, 11:07 PM Thread Starter
REDSOX2758's Avatar
Yes ive got a mig welder and am probably gonna go with the bracket route, thanks for all the input guys! Any other tips about installing them along the way?
2004 F-250 6.0
117,XXX miles
3 inch lift
18X9 XD Series Hoss
35" Toyo m/t's
Train horns
5% Tint
post #9 of 15 (permalink) Old 03-17-2010, 07:06 PM Thread Starter
REDSOX2758's Avatar
Ok, I managed to get everything in today, now im just down to the wiring. Anyone know which wire is for the horn trigger so I can tie a toggle switch into it?
2004 F-250 6.0
117,XXX miles
3 inch lift
18X9 XD Series Hoss
35" Toyo m/t's
Train horns
5% Tint
post #10 of 15 (permalink) Old 03-17-2010, 09:56 PM
TxFireman1972's Avatar
Attachment 11467
Just out of curiosity....how much is a setup like that?
2005 F350 Crew Cab 4x4
PMF Rear Leaf Spring Conversion w/2011 Leaf Springs
20" Harley Wheels 305/55/20 Nitto Terra Grapplers
SCT X3 w/GearHead Tunes
Amp Steps, Bedrug, HID's
TxFireman1972 is offline
