How to dyno... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 03-15-2010, 02:13 PM Thread Starter
BRING DA AMBALAMPS
stroke of luck's Avatar
How to dyno...
I'm going to hit the rollers pretty soon so I was wanting good advice on how to load, what gear to go in (OD or not), how many rpm's to go to etc, etc. I'm sure the first time, I'll let a pro do it for me but I'd still like to know how myself. Thanks!
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #2 of 7 (permalink) Old 03-15-2010, 02:23 PM
FordSuperDuty05's Avatar
Re: How to dyno...
suscribed to this id like to know myself cause id like to put mine on the rollers soon
2011 F-350 Crew Cab Long Bed FX4 King Ranch
FordSuperDuty05 is offline
post #3 of 7 (permalink) Old 03-15-2010, 02:26 PM Thread Starter
BRING DA AMBALAMPS
Re: How to dyno...
hey randall....i'm trying to dig up some info for the Bully Dog Dyno Day. Hoping to get on the rollers there.
post #4 of 7 (permalink) Old 03-15-2010, 02:37 PM
Peon
jvencius's Avatar
Re: How to dyno...
Try looking in the Dyno forum...
jvencius is offline
post #5 of 7 (permalink) Old 03-15-2010, 02:49 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
Re: How to dyno...
lots of good how too write ups in there
Usually with these trucks since there is no direct way to just lock out OD, they run the truck in OD
Basically you will get the truck rolling, get it to shift into OD and hold it there just into the gear, around 50mph and maybe 1250-1500 rpm or so. When you give the operator the nod, or he gives you the nod and pushes the button you will want to get the pedal to the floor as fast as possible BUT without forcing the trans to downshift, seemed once you were over 2,000rpm it was good. So roll your foot into the pedal as quick as you can but without downshifting and have it to the floor by the time the truck hits 2k rpm. From there just hold it till you tach out around 4k and then lift. Sometimes the brakes help in lighting the turbo down low, or you might find some other pedeling tricks that work for your truck, but its pretty straight forward once you go through the process.
Video of one of my runs Dyno Day April 09 :: MOV02550.flv video by bareorn - Photobucket
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #6 of 7 (permalink) Old 03-15-2010, 02:51 PM
The Fireman
big_stroker's Avatar
Re: How to dyno...
Normally when you have your truck dynoed you don't run it. The people the own the dyno will.
But to get an accurate reading you bring the truck up slowly to your direct drive gear so you have a 1:1 ratio.
You dont want it to down shift or shift into OD
big_stroker is offline
post #7 of 7 (permalink) Old 03-15-2010, 02:57 PM Thread Starter
BRING DA AMBALAMPS
Re: How to dyno...
i forgot there even was a forum just for dyno stuff...mods feel free to toss it over to the dyno forum, sorry.
good info jdc...thanks!
