Stacks... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 03-13-2010, 09:15 PM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Stacks...
I have never been a big fan of stacks on pickups. They look good on some trucks and set up right...
Here is the deal...
I am running on a low compression used motor right now, and to make matters worse I am at 5500' right now in Prescott. Add to that a rather large turbo that takes a bit to light and you can guess... I smoke a bit.
Even without trying I will blow out a huge cloud until the turbo lights. I really try to tenderfoot it off stop lights and can control it quite well once underway.
I am thinking of adding a single 5" or 6" stack on the drivers side, just to get it up off the ground so I dont smoke everyone out... cant run more then a single due to the fuel tank and tool box in the bed.
So questions are,
Those of you with stacks, loud in the cab when cruising? Soot all over the truck when warming up? would you do it again?
Joe
CSIPSD is offline
post #2 of 21 (permalink) Old 03-14-2010, 12:23 AM
MINK
Comp7.3's Avatar
Re: Stacks...
alot louder in the cab...my truck is black so the soot aint bad but I also try to wash mine once a week.
Josh Mink
CAMB MOTORSPORTS
Comp7.3 is offline
post #3 of 21 (permalink) Old 03-14-2010, 12:30 AM
Lovin Life...
02BigD's Avatar
Re: Stacks...
Single Aussie should give you enough exhaust velocity to keep most of the soot off the truck. I've been told that aussies and turnouts are the quietest in the cab, but cannot personally confirm that as all I've run is twin Aussies. For me, even with headers, it is easy to have a normal conversation in the cab. I have a crew cab.
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #4 of 21 (permalink) Old 03-14-2010, 12:31 AM
Myles_S's Avatar
Re: Stacks...
I've got a white truck and single 6" I do notice I get alot of little black specs on top of my cab from startup after a heavy dew or light rain. Other than that no soot problems.
In cab noise is definately pronounced but as long as you mount the top of the stack above the cab it's bearable.
Even with a stack I can still make cars hit their brakes, but it is alot better than shooting it out the side.
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #5 of 21 (permalink) Old 03-14-2010, 12:32 AM
Re: Stacks...
Sound in the cab isnt that bad while cruising...but when you're taking off or heavy footin it you cant really talk in the cab...
I have a white truck and rarely ever see any soot on the truck.
All in all Im very pleased with mine, but if your sole purpose is to not smoke people out then stacks wont help that much as the smoke goes directly behind the truck...seems like blowing it out the side over the shoulder of the road would actually be better...
Rubenk is offline
post #6 of 21 (permalink) Old 03-14-2010, 12:36 AM Thread Starter
CSIPSD's Avatar
Re: Stacks...
Duals...
With my old stage 2's... for example.
I would go with a single turnout clear to the passanger side...
Joe
CSIPSD is offline
post #7 of 21 (permalink) Old 03-14-2010, 12:48 AM
Re: Stacks...
Originally Posted by CSIPSD View Post
Duals...
stock exit exhaust... looks like the road is clearer than with my stacks..
Rubenk is offline
post #8 of 21 (permalink) Old 03-14-2010, 01:10 AM
7.3 King Ranch's Avatar
Re: Stacks...
Just removed my 7" mitres after 2 years. There is zero way you will not have soot flakes all over a white truck. Soot builds up and eventually flakes off and out. It was loud inside with the CC. I do miss the look/sound at times, but had enough for now... Rain/snow also makes for a nice treat
00 F250 CC SB 35's, .......
7.3 King Ranch is offline
post #9 of 21 (permalink) Old 03-14-2010, 01:17 AM
moore20017.3's Avatar
Re: Stacks...
Soot all over the truck, black slushy water all over the whole thing, loud as hell and annoying.
Mine is getting a nice 5'' out the rear as soon as I have time. I am still dd'ing the truck all over and I hate it. I did it for the pulling rules, but I do not have time or money to break stuff now that I have a lil power.
I did run a set of aluminum dual stacks that I built that were real qiuet, this single is anything but quiet.
I think there is more smoke in the road with the stack(s) than without.
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #10 of 21 (permalink) Old 03-14-2010, 01:21 AM Thread Starter
CSIPSD's Avatar
Re: Stacks...
hummmm... I was hoping to get it off the road a bit... Really, I am not a smoker, and hate it.
But I can not afford a new motor right now... 5500 feet is not helping!
Joe
CSIPSD is offline
