7.3 leaf spring help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-17-2018, 03:07 AM Thread Starter
Shuggy619's Avatar
I have a 03 7.3, I bought the truck with a 4” lift on it and have been told that to get the lift off and level it I will need stock leaf springs. I’m having trouble finding springs, at least some with lower mileage.
I finally found some springs with 150000 on them, but the guy recently sold the truck. He gave me a pic with the stamp on the codes, and I am hoping someone can help me verify what spring code these actually are?
YC35AMC
PPN2880
Also,
Is there an option of finding a level kit that doesn’t require me finding stock springs? Thanks in advance
Shuggy619
2003 F250 CCSB 7.3 Lariat
S&B intake
PHP SWAMPS tuned
ISSPRO gauges
Straight piped
Shuggy619 is offline
post #2 of 2 (permalink) Old 04-17-2018, 11:53 AM
Moderator
Sbluke55's Avatar
Re: 7.3 leaf spring help
Pro comp 22210 or factory x codes from ford or sdtruck springs. Those both will level your truck. Just remember that when you lower the truck, you will need the stock pitman arm, track bar bracket, sway bar brackets or links, and shorter blocks.
01 f-250, Standard
Sbluke55 is offline
