Purchased A 6.0 Good Or Bad? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 04-04-2018, 07:18 PM Thread Starter
I just purchased a 2004 f350 with the 6.0l turbo diesel I have heard a lot of good things and bad things about this engine. The truck currently has 227,000 on it. It's not bulletproofed completely stock. Is there anything I should do to it? I'm new to the 6.0 engines. Thanks!
Alex2669 is offline
post #2 of 12 (permalink) Old 04-04-2018, 07:58 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: Purchased A 6.0 Good Or Bad?
Bulletproof it. ARP headstuds and egr delete. New ford oil cooler. Re-seal injectors and everything else that you take apart
Sent from my SM-J320V using Tapatalk
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 12 (permalink) Old 04-04-2018, 08:23 PM
​ DieselDC's Avatar
Bulletproofdiesel.com
EGR delete $792
BPD oil cooler $2045
Head Gasket $1310
Heads new $2300 https://kcturbos.net/products/6-0-po...cylinder-heads
Injector 175/30 $2000
O-ring heads $1500
HPOP $1300 (dieselsite)
Ficm $821
Water pump $350
=$10,118 ($12,418 if new heads from kcturbo)
​ DieselDC is offline
post #4 of 12 (permalink) Old 04-04-2018, 09:05 PM Thread Starter
Thank you
Alex2669 is offline
post #5 of 12 (permalink) Old 04-04-2018, 09:05 PM Thread Starter
EGR delete $792
Head Gasket $1310
O-ring heads $1500
Ficm $821
Water pump $350
Thanks I appreciate your time.
Alex2669 is offline
post #6 of 12 (permalink) Old 04-04-2018, 09:23 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
also, it would likely benefit you to know whether this is an early or late build motor. there's subtle differences, but they are important when there's a problem! easierst way to tell is if the ICP sensor is onthe passenger side valve cover towards the front of motor, that's a late build. if its down in the valley under the turbo then its an early build
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #7 of 12 (permalink) Old 04-04-2018, 09:26 PM
Turd-250's Avatar
oh, and figure out the type & age of ALL of the existing fluids you have installed. and then proceed to change the old ones and replace teh incorrect ones with quality fluid. one of the most common "fluids" mistakes on the 6.0 is using the universal green or ford gold coolant in a 6.0. it really needs a quality ELC with an EC-1 rating in the cooling system
Turd-250 is offline
post #8 of 12 (permalink) Old 04-04-2018, 09:29 PM
Turd-250's Avatar
& i'll add in these because i didn't read them in the above posts: updated standpipes/dummy plugs if needed, and blue spring upgrade FPR.
do you have any service records for the truck? would be nice to know for sure if anything has been done to it. if you know the dealership that it was serviced at, they will send you the records that they have for the VIN. i've done that before.
Turd-250 is offline
post #9 of 12 (permalink) Old 04-05-2018, 02:09 PM
You can do all that stuff right away. However, if its running good why would you? Save that stuff for later down the road when it needs it unless you like spending money. Many of these trucks have gone more miles than that on stock hardware.
I would flush the coolant if it has the Ford Gold in it and replace it with a CAT ELC equivalent. I believe between the dirty blocks, Ford Gold coolant without flushes, and poor EGR coolers are what gave the 6.0 such a bad name. Check your temps for oil and coolant to see what the deltas are. If the deltas are more than 15 at 60mph on flat ground you need to back flush the oil cooler and possibly replace it. No need for a BPD oil cooler, the Ford cooler works just fine and is about $2000 cheaper. If you replace the oil cooler get rid of the EGR cooler at that time or replace it with the BPD cooler. Replace the injectors only if needed. With over 220k miles they have probably been done.
Turbospin is offline
post #10 of 12 (permalink) Old 04-05-2018, 03:15 PM
Turd-250's Avatar
oh yeah, i forgot, there's that braided updated turbo drain tube too iirc...
Turd-250 is offline
