Painting oil cooler? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-04-2018, 12:31 PM Thread Starter
Anyone done it?
loganhorse is offline
post #2 of 9 (permalink) Old 03-04-2018, 12:38 PM
PSN intsigator
heavydoc's Avatar
Re: Painting oil cooler?
Can't say that I have
sig should be here
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #3 of 9 (permalink) Old 03-04-2018, 12:46 PM
​ DieselDC's Avatar
For what? Thatís like people painting their intercooler black to ďmatchĒ or hide it. Something that exchanges heat with air will not do an efficient job with paint on it. Iíve seen many done with no ill effects but Iím not going to do it with my oil/trans/intercooler.
Edit: you should try it and treat it like a scientific experiment. Measure before and after temps and let us know what your findings are?!
​ DieselDC is offline
post #4 of 9 (permalink) Old 03-04-2018, 12:49 PM Thread Starter
I was thinking more for protection of rust. Mine looks terrible and its out for seals.
post #5 of 9 (permalink) Old 03-04-2018, 01:26 PM
Native Texan
masakimm's Avatar
Garage
There should be no problem since it is a fluid to fluid cooler. With it out should be easy to paint just mask off the areas where the orings are before u paint it unless you are going to assemble it then paint it then just keep the paint from the sealing surfaces for the block.
Sent from my super awsome outdated new Samsung phone whose 500mA draw hasn't over-overloaded multiple already over rated branch circuits just beyond the kaboom point and caught everything on fire yet.
Upgrades:
masakimm is offline
post #6 of 9 (permalink) Old 03-04-2018, 01:27 PM
Native Texan
masakimm's Avatar
Garage
And post some pics.
Upgrades:
masakimm is offline
post #7 of 9 (permalink) Old 03-04-2018, 02:29 PM
​ DieselDC's Avatar
Oh okay when you say rusting Iím now thinking oil cooler as in the one below the driver headers! I was thinking oil cooler as in oil transmission cooler. Sorry early in the am haha. Yes paint that sob! Make sure you soak it in kerosene to clean it up good - helps loosen the crud in there.
post #8 of 9 (permalink) Old 03-04-2018, 02:35 PM Thread Starter
No sir! Done alot of stupid stuff but a air to fluid cooler is not somethin I'd paint. Lol.
I'll post pictures when im done.
post #9 of 9 (permalink) Old 03-04-2018, 05:14 PM
79jasper's Avatar
There is some paint out there for painting radiators. Obviously never seen equipment radiators. Lol
But people like using the stuff on 2 cycle engines.
79jasper is offline
