What hitches do you use for "bumper" towing? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-03-2018, 06:57 AM Thread Starter
Not exactly bumper pull towing, but what I mean is not goose neck or 5th wheel towing
I recently got a 4 inch drop hitch for my 2006 4x4 F350 to tow my open top car trailer
But the hitch says it's rated for a 5k pound load and the 2 inch ball says it's rated for a 6k pound load
My car trailer is a dual 3500 pound axle set up and is about 2k pounds or so empty and my race car I usually tow is about 2800 pounds or so, plus a few tires on my trailer's tire rack
The trailer + car + tires is well within the 7k pound capacity of the trailer, but that exceeds the 4 inch drop hitch's 5k capacity
Am I doing something wrong here or not seeing something? I need a drop hitch for my truck since the truck is fairly tall even just on stock ride height and tires, which reduces the load capacity a bit. But even then, with a 2 inch receiver it I can't seem to find a hitch that goes anything over 6k pounds
I know there's something out there. I've seen guys bumper pull a 2 car trailer no problem and that's probably in the 8-10k range easily
koukimonster is offline
post #2 of 12 (permalink) Old 03-03-2018, 01:03 PM
​ DieselDC's Avatar
Get that and be done with it. I have it. Failed? Never. Abused? Yes, yes all the time. You wonít find a better hitch for the price unless you want to spend several hundred for a hitch rated to tow 25-30k yet no idiot would bumper tow that much.
​ DieselDC is offline
post #3 of 12 (permalink) Old 03-03-2018, 01:15 PM
Moderator
Sbluke55's Avatar
Re: What hitches do you use for "bumper" towing?
That's a bad link.
01 f-250, Standard
Sbluke55 is offline
post #4 of 12 (permalink) Old 03-03-2018, 01:54 PM
Randy4614's Avatar
I think you are confusing tongue weight with trailer weight. If you look at say like Curt hitch site or even on Amazon There are a lot of Class 5 drop hitches well over 10,000 trailer weight .
On my own truck just bought , a 1999 F350 4x4 dually, I am replace the factory 10,000 # receiver hitch with a Curt Heavy Duty Class 5 17,000 hitch and also with be getting a new weight distributing hitching with 1700# bars. I pull a fairly heavy equipment trailer , non-goose neck, and want the extra safety.
Randy4614 is online now
post #5 of 12 (permalink) Old 03-03-2018, 02:37 PM
​ DieselDC's Avatar
Originally Posted by Sbluke55 View Post
That's a bad link.
Thank you - should work now. Uploaded a photo justnin case.
post #6 of 12 (permalink) Old 03-03-2018, 02:49 PM
Randy4614's Avatar
Although that might be a good hitch, personally I think I would prefer the 2 pin design ones.
post #7 of 12 (permalink) Old 03-03-2018, 02:54 PM
​ DieselDC's Avatar
Itís a great hitch. I got it b/c it was one pin. Didnít want to mess with two pins. That thing is solid steel and the pin is set in the middle and braced by its ends and the drop frame itself. For the money, Iím satisfied. I wasnít going to spend hundreds on something built 100x stronger and for which I will never exceed. I got my GN for them heavy weights.
post #8 of 12 (permalink) Old 03-03-2018, 03:31 PM
Randy4614's Avatar
Guess that is why it is always nice to hear personal experience from someone on a product.
post #9 of 12 (permalink) Old 03-03-2018, 09:12 PM Thread Starter
that's not a bad price for an adjustable heavy duty hitch, actually. I might pick that one up
I was looking around at walmart, harbor freight, lowes, etc and all I could find were hitches like this
Reese - Class III/IV: 2? Ball Mounts
I know class 5 hitches are pretty beefy but my truck came from the factory with a class 4 hitch which has a 2" receiver. I see the difference in tongue weight and trailer weight. The tongue weight on these things are in the upper hundreds and the trailer weight is around 6000 or so
post #10 of 12 (permalink) Old 03-03-2018, 09:19 PM Thread Starter
What do you think of this curt unit? It seems like this is the hitch that would be able to tow a triple axle bumper pull enclosed or a large flat bed load of hay to me
https://www.ebay.com/itm/CURT-45900-...oAAOSwAPVZJYks
