F250 4x4 hubs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-04-2010, 12:24 PM Thread Starter
Fixing Broken Stuff
toolmangary's Avatar
Question F250 4x4 hubs
Whats needed to take apart the front hubs on a 2007 SD 4x4, I thought I seen that there is a "special vacuum tool" and you should always change the o rings. The axle u joints need to be replaced Thanks
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #2 of 3 (permalink) Old 03-04-2010, 04:29 PM Thread Starter
Fixing Broken Stuff
Re: F250 4x4 hubs
well, looking at this F250 it is an XL and has manual hubs, I see the port on the knuckle for the vacuum line on trucks with automatic hubs. I see a special tool will be needed to seat the axle seal, looks like OTC makes what I need
2004 Jetta TDI
1956 F100
post #3 of 3 (permalink) Old 03-04-2010, 04:49 PM
NevrKnow's Avatar
Re: F250 4x4 hubs
Or you can make one yourself from some homedepot parts.
2002 F-250 SD Lariat CC 4x4
7.3L automatic.
Underdash gauge pod with ISSPRO gauges.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
4" turbo back straight exhaust and 4-6" Silverline chrome tip.
20" wheels with 32x12.5 Toyo MT's
'08 aluminum rear diff cover.
SOLID AXLE front cover.
A/C Mod
NevrKnow is offline
