Looking for more lift any ideas? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-03-2010, 01:43 AM Thread Starter
UniDub's Avatar
I have a 6" lift now and i am looking to go another 4-5" with ladder bars.. Not really looking to spend alot more either.. This is it now..Anyone have any ideas?
'03 6.0 CrewCab FX4 6" lift.. 38x15.5x20 Nitto Mud Grapplers on Moto Metal MO954 wheels straight piped and Looney tuned..
Slicker then snot on a chickens lip...
UniDub is offline
post #2 of 12 (permalink) Old 03-03-2010, 01:51 AM
Texas7.3
Re: Looking for more lift any ideas?
is it coil over or leafs?
02' f-350 8-inch lift 40's 5" exhaust, 6 position chip from david at DI
Chris
BigTXForddiesel is offline
post #3 of 12 (permalink) Old 03-03-2010, 01:54 AM
dzljon's Avatar
i have 3" icon hangars, they are great, kinda expensive but it may be the ticket for you. they even have a 4.5 hangar kit
ICON Vehicle Dynamics
99.5 F250/ VGT 5.9 CR Cummins4 link front and rear air ride
dzljon is offline
post #4 of 12 (permalink) Old 03-03-2010, 02:28 AM
Layson's Avatar
If you stay under 9" then it is going to be cheaper... start going over 10-12 and it starts really costing $$ to do it right...
Contact the Pro... DCspecial.. or Marty at Truck Toyz!
Layson is offline
post #5 of 12 (permalink) Old 03-03-2010, 09:24 AM
Powersmokesd's Avatar
Sky manuf. has a shackle-hanger kit that is 4.5 inches for around 400 bucks. they also have a rear flip kit that is 4.5 inches. Better than stacking blocks!
Rollin' Black Smoke!
Powersmokesd is offline
post #6 of 12 (permalink) Old 03-03-2010, 01:05 PM
NEVRNF's Avatar
You have past the cheap point over 9". New shocks, swaybar links, crossover steering, brake hoses, high angle front drive shaft or indexing ring and crossmembe. The Sky rear flip is a great way to go. OR Fabtech makes a 3" drop. Plan on 2K+ to go up 4-5"
Tony
02 Excursion CR conversion with a few go fast parts
The truck
should have built
FOR SALE
NEVRNF is offline
post #7 of 12 (permalink) Old 03-09-2010, 02:51 AM
either do cut out fender flares and have a body shop put them on right or get your fenders "tucked and rolled" but a body shop. This way you keep the same suspension but make bigger openings in the fenders for larger meats, also you don't fall over in a stiff breeze.
micky
micky_blue is offline
post #8 of 12 (permalink) Old 03-11-2010, 09:34 PM
reluctant ford fan
Hadnt heard of Sky before this, so thanks for the pointer! My X is currently lifted about 3 with front & rear springs. If I wanted to go up another 2, Skys front hanger system would be an economical way to get there up front. In back, the X has the stock blocks which I believe are 2.5 or close to. Could I use Skys rear flip (+4.5) and get rid of the stock blocks (-2.5) to come up with a net of 2 lift in back, or are the blocks needed? Any reason I wouldnt want to go this way?
04 X/4wd/EB/6.no-leaker thanks to Strictly Diesel!
brian is offline
post #9 of 12 (permalink) Old 03-11-2010, 10:49 PM
Evil Genius
DCSpecial's Avatar
As mentioned, once you go over 9" of lift it starts to get pricey with the need for crossover steering, relocated trac bar setup, etc..
DCSpecial is offline
post #10 of 12 (permalink) Old 03-11-2010, 11:58 PM
powerstroke710's Avatar
what about a 3" body lift or are body lifts not popular anymore? they are cheap. i personally don't like to see a lot of frame, which can come a long with a body lift. you could go 3" body, a 2" hanger in the front, and a 2" block or add-a-leaf in the rear. there you would have 4-5"s of lift. that would be cheap and you wouldn't have any driveline issues. i have 8"s of suspension on mine without any driveline issues. just wanted to throw my opion out there.
2000 f-350 eclb lariet 7.3l, 8" lift, 18" rockstars, 37" nittos,projector headlights, euro tailights, recon led third brake light, recon clear cab lights, pocket flares, auto to 6 speed swap, south bend clutch,edge juice/attitude, superchips stacked, 5" exhaust to 6" stacks, diy intake.
powerstroke710 is offline
