Replacement Power Steering Pump? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-28-2010, 07:12 PM Thread Starter
TxFireman1972's Avatar
Well I noticed a little dripping under the truck. Climbed under there and the pump is soaked. Also the fluid in the reservoir is real low. Not sure if its the pump or the hose. Wont have time to tear into it till tommorow. Curious if anyone sells a aftermarket power steering pump for 05-07 F250/F350?
Anyone have anything for it? Where at and how much? I'm running 37's so really dont think I need to get into hydraulic ram steering or anything like that. Let me know whats out there without breaking the bank lol.
2005 F350 Crew Cab 4x4
PMF Rear Leaf Spring Conversion w/2011 Leaf Springs
20" Harley Wheels 305/55/20 Nitto Terra Grapplers
SCT X3 w/GearHead Tunes
Amp Steps, Bedrug, HID's
TxFireman1972 is offline
post #2 of 9 (permalink) Old 02-28-2010, 07:58 PM
REDSOX2758's Avatar
Re: Replacement Power Steering Pump?
Mine is also soaked... Im interested as well.
2004 F-250 6.0
117,XXX miles
05 front end conversion
Innovative's SCT tunes
ISSPRO EV LED gauges
7 inch single... straight piped
3 inch lift
18X9 XD Series Hoss
35" Toyo m/t's
Train horns
5% Tint
Best 1/4 - 13.96 at 95.46 MPH
REDSOX2758 is offline
post #3 of 9 (permalink) Old 03-01-2010, 04:02 AM
roughneck0913's Avatar
i have replaced a bunch of the pressure hoses due to them leaking I have not seen many bad pumps.....
roughneck0913 is offline
post #4 of 9 (permalink) Old 03-01-2010, 02:04 PM Thread Starter
Where did your hose leak from? It may be the hose, hard to tell.
post #5 of 9 (permalink) Old 03-01-2010, 02:09 PM
Jomax's Avatar
I got a auto zone pump sitting in my garage that needs to go in my truck wasnt that much cheaper then the dealer as i recall.
2000 F-350 4x4 DRW 200,000 miles DP tuner Stock, 40T, decel, 60T, 80T, 80eco, 120race, ported compressor housing, bellowed up-pipes, Terminator T-500, FPR Spring mod, AIH delete, autometer ford factory match boost, pyro, trans, HPX crossover tube, AFE Stage II CAI, 5in Straight pipe, JW valve body, Deep transmission Pan with magnet
Jomax is offline
post #6 of 9 (permalink) Old 03-01-2010, 02:30 PM
Viking's Avatar
Get a hold of these guys
http://www.redheadsteeringgears.com/
Viking is offline
post #7 of 9 (permalink) Old 03-01-2010, 07:55 PM
most of the hoses are leaking where the rubber is crimped to the steel line
post #8 of 9 (permalink) Old 03-01-2010, 08:18 PM
06powerstroke's Avatar
Mine leaks too, thought I was the only one. I found one leak and fixed it, but it seems I still have another one. Must be down by the pump because it is covered in oil, my first leak was the compression fitting on the booster.
2006 F250 CC LB FX4 Lariat
ARP studs, SCT X3 IDP & Gearhead tuned, S&B CAI, straight pipe, FASS 150/180, FCDP solid uppipe, Dieselsite coolant filter
2.5" BTS leveling kit, 35" Xtreme A/T's on XD Hoss 18's, N-Fab prerunner bar w/ 3 9" Hellas
Pioneer double din, JL components, 3 10" Pioneer subs
06powerstroke is offline
post #9 of 9 (permalink) Old 03-01-2010, 10:58 PM
Viking's Avatar
If its the hose then check that crappy teflon o-ring, its hard as heck to get on and can damage easily. I went through 2 this winter replacing it in the driveway.
Viking is offline
