Ford Dually on 35's - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 38 (permalink) Old 02-24-2010, 03:32 AM Thread Starter
Jomax's Avatar
Ford Dually on 35's
Hey got a good deal on 35in tires on polished stock wheels, and also found a good deal on a 4in lift kit. So the question is what size rear spacer to fit the rear tires????
2000 F-350 4x4 DRW 200,000 miles DP tuner Stock, 40T, decel, 60T, 80T, 80eco, 120race, ported compressor housing, bellowed up-pipes, Terminator T-500, FPR Spring mod, AIH delete, autometer ford factory match boost, pyro, trans, HPX crossover tube, AFE Stage II CAI, 5in Straight pipe, JW valve body, Deep transmission Pan with magnet
Jomax is offline
post #2 of 38 (permalink) Old 02-24-2010, 03:37 AM
7.3powerstroke03's Avatar
Send a message via Yahoo to 7.3powerstroke03
Re: Ford Dually on 35's
if they are 12.5 wide id say a 2.5 inch would prob be enough, i ran 33 12.5 on a obs with 2 inch spacers they were really close but never had problems, only thing if you tow you might want lil extra room to keep sidewalls from rubbing
2000 F250 reg cab 4x4 6spd 270k
7.3powerstroke03 is offline
post #3 of 38 (permalink) Old 02-24-2010, 03:40 AM Thread Starter
Jomax's Avatar
So 2.5???
Jomax is offline
post #4 of 38 (permalink) Old 02-24-2010, 03:45 AM
C&C Customs
Cory_S's Avatar
2.5 should be plenty
stage 11 tranny by Doug @GoGo
And a lot of other goods
_____CORY
Cory_S is offline
post #5 of 38 (permalink) Old 02-24-2010, 03:46 AM
i would think that would be enough since mine cleared with 2 inch but it was close enough you could barely stick a finger between them
post #6 of 38 (permalink) Old 02-24-2010, 05:03 AM
Grumpy Old Bitter Bastard
389SixPack's Avatar
I would go to a 2" and if there are issues, you should have enough stud length to add a 1/2" spacer.
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
389SixPack is offline
post #7 of 38 (permalink) Old 02-24-2010, 03:58 PM Thread Starter
Jomax's Avatar
I will pull some heavy weight, one would be a 13,000-15,000lb bumper pull toy hauler. should i worry if i have the 2in????
Jomax is offline
post #8 of 38 (permalink) Old 02-24-2010, 04:10 PM
Lovin the Tuna
RedSmokey's Avatar
My buddy ran ORU's dually spacers on his old dually with 4" lift and 35x12.50 tires. He is supposed to send me some pics later, hopefully has some good ones straight from the back to see. He hasnt had the truck for a while, but was saying he thinks there was about 1.5" space between the treads.
On Edit: ORU says on their site that you can run 12.50 wide tires with their spacers. Im trying to find out the actual size (so you could get any brand spacer your looking at). But my buddy thinks they were 2"
2001 F250
2000 F250
RedSmokey is offline
post #9 of 38 (permalink) Old 02-24-2010, 04:22 PM Thread Starter
Jomax's Avatar
These are the ones I'm thinking of WheelAdapter.com Wheel Adapters
Jomax is offline
post #10 of 38 (permalink) Old 02-24-2010, 04:45 PM
Lovin the Tuna
RedSmokey's Avatar
This is my buddy's old truck. 4" lift, 35x12.50 bfg muds on stock wheels. He had ORU dually spacers on the rear.
This is a good shot of the space. Pretty sure you would be able to haul heavy and not have to worry about sidewalls touching.
2001 F250
2000 F250
