2008+ mirror conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 09-10-2017, 09:52 PM Thread Starter
any one know if you can by adapters for the 08+ mirrors to fit the 01 Superduty wiring in the door or does any one know the exact pin out from the new mirrors to and the exact pin out for the factory wireing. i have buyt a set of mirrors that have heat, turn and marker. i have the marker, turn, and heat hooked up and only holding up with the mirror turn functions. i have the door plkug with only mirror function.. no heat turn or marker. pleaes help
MBME051731 is offline
post #2 of 4 (permalink) Old 09-10-2017, 10:29 PM
alleged moderator
tjctransport's Avatar
Re: 2008+ mirror conversion
01 did not come with those functions so you will have to run the wires out through the dash and doors to the mirrors.
tom
tjctransport is offline
post #3 of 4 (permalink) Old 09-16-2017, 08:25 AM
Garage
Search 08 mirror install in older sd trucks. Theres a bunch of writeups on how to wire everything. Pretty easy couple hours work,
1999 F350 Ext cab LB UFiberglass utility body SRW 4x4 auto
Magnaflow 4" turbo back
PHP Hydra with swamps tunes
08 style tow mirrors
jesse24spd is offline
post #4 of 4 (permalink) Old 09-24-2017, 06:43 PM
Resident Curmudgeon
Toybreaker's Avatar
Garage
Send a message via Yahoo to Toybreaker
Doing it myself right now. Write ups dont cover everything.
My new mirrors have
Red
Yellow
green
blue
Grey
White
Black wires
Old
Red
Yellow
Blue. (Drivers side)
The ebay adapters do not correspond on color and do not fit the connector on the mirror.
I do not have time to go back and forth with the seller so i am cutting and splicing
Cant add photos from my phone
Toybreaker is offline
