Need help with trick exhaust - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 02-21-2010, 08:56 PM Thread Starter
BRING DA AMBALAMPS
stroke of luck's Avatar
Hey guys...I'm planning on running my exhaust out the side through the body kind of like the pic below. does anyone know where I can find a cut out flange kind of like the one shown? I've googled the hell out of it but can't find one anywhere.
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #2 of 29 (permalink) Old 02-21-2010, 09:16 PM
Offical Puddle Displacer
pstroke96's Avatar
Send a message via AIM to pstroke96
Re: Need help with trick exhaust
where do you plan on it exiting?
if its near the front the whole side of the truck is going to be covered with soot.
i wouldnt do it to my truck but it would definatley stand out
also, it would also be one big @ss hole in the side of your truck
Refugee
pstroke96 is offline
post #3 of 29 (permalink) Old 02-21-2010, 09:22 PM
FREE THINKER
Chip's Avatar
Looks like it would be realy easy to fab up...do you have any welding skills?That would be pretty slick,if you were alittle closer i could help you out.
1999 7.3, 2wd ,auto
Chip is offline
post #4 of 29 (permalink) Old 02-21-2010, 09:35 PM Thread Starter
BRING DA AMBALAMPS
the piping part would be relatively to fab but i know there are pre fab'd kits out there. i see them on the sides of boats all the time. i did find this part which might work out but they want nearly $400!!!
my exhaust exits in front of the rear tire now and as far as smoke on the side goes...i'm not too worried about it. I wash my truck once a week at the very least and I'm not running smokey tunes at all. either way...i think a little soot would be worth having a set up like this!
post #5 of 29 (permalink) Old 02-21-2010, 09:39 PM
FREE THINKER
Chip's Avatar
Is the $400 for a set or just one...eather way thats pricey,i would keep lookin!
1999 7.3, 2wd ,auto
Chip is offline
post #6 of 29 (permalink) Old 02-22-2010, 01:37 AM Thread Starter
BRING DA AMBALAMPS
what if I did a straight cut tip like this and only had it stick out about 1/2" or so past the flange?
post #7 of 29 (permalink) Old 02-22-2010, 02:21 AM
Haters Gonna Hate
Fordfreak4life's Avatar
i think it would look B A.... but the first one would be alot cleaner lookin... just my .02
Fordfreak4life is offline
post #8 of 29 (permalink) Old 02-22-2010, 02:30 AM
pstroke96's Avatar
i would go with the flush one, and looking at that tip if you have welding skills or know someone that does, it could be done pretty easily
Refugee
post #9 of 29 (permalink) Old 02-22-2010, 02:41 AM Thread Starter
BRING DA AMBALAMPS
it's times like this i wish i had a tig sittin in my garage! i think my neighbor and I are going to work on this next weekend.
post #10 of 29 (permalink) Old 02-22-2010, 03:02 AM
Attention Whore
UNBROKEN's Avatar
Get some 16 gauge sheet metal and roll it by hand to fit the curve of the truck.
Cut whatever size pipe you want to the angle you want it to exit.
Trace pipe onto inside of plate.
Cut out hole.
Insert pipe and weld around inside.
Trim off excess that's sticking out.
Weld around that cut and finish the weld smooth with a flapper disc on a 4" grinder.
Paint or chrome it when it's done.
Cut big ass hole in side of truck and mount the plate.
When you mount the exhaust to the piece you made use flex tubing so it can all move with the truck.
I'd bet you can knock it out for 50 bucks plus whatever finish you want on it.
Spending money I don't have on crap I don't need to impress people I don't know.
UNBROKEN is offline
