I just bought my first Ford but hate the rims and tires! - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 15 (permalink) Old 09-01-2017, 07:28 PM Thread Starter
Spectre77's Avatar
Personally I like a rim and tire that sits more in the wheel well. I would also like to go from the 35 inch tall that are on it to a 33 inch tall on a 17 or 18 inch rim...it's just not my style. So I try to read everything before posting and if I understand correctly a stock room is like a +40 offset. .??? I would really like a tire and rim combination that would not only puts smaller tires on but move the tire more underneath the truck. It does have a 4 inch lift and I was thinking like a 275 70 r18 or a 285 70 r17 tire. For a 18 inch rim the offset of +20 the back space is like 5.75. Or it comes in a offset or 1 and a backspace of 5. Only reason I've been looking at 18s is because there is a lot more selection the 17s are more limited but are less expensive. I included pictures of my truck I guess I'm just getting old and like it to be a little more user-friendly I only bought it because it was in great condition otherwise. I'm just trying to wrap my head around doing it right without rubbiN' Thank you is advance for the read and the advice
Spectre77 is offline
post #2 of 15 (permalink) Old 09-01-2017, 08:13 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: I just bought my first Ford but hate the rims and tires!
welcome to the forum! & welcome to fords!
i agree with you on the rims and tires, i like them underneath the vehicle lol! given the 4" of lift, i want to say your truck should have no problem rubbing with 17" stock offset rims & 285/75/17s which are a 33" tire iirc. but id like to hear more!
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #3 of 15 (permalink) Old 09-01-2017, 08:29 PM
Native Texan
masakimm's Avatar
Garage
to the nation. Yap those wheels suck. Im thinking bout doing an axle swap on my truck out of a newer e450 but it will add an extra 1 on each side and im trying to decide if the disk brakes and heavier axle are worth that.
Sent from my Super awesome outdated Samsung that doesn't burst into flames using Tapatalk
Upgrades:
masakimm is offline
post #4 of 15 (permalink) Old 09-01-2017, 11:22 PM Thread Starter
Spectre77's Avatar
Thank you, the paint is in such great shape soon as I start taking it up and down the dirt roads that won't last long.
post #5 of 15 (permalink) Old 09-01-2017, 11:47 PM
alleged moderator
tjctransport's Avatar
look at the 2011 and newer rims.
the 18 inch rims will bolt rite on to your truck.
tom
tjctransport is offline
post #6 of 15 (permalink) Old 09-02-2017, 02:25 AM Thread Starter
Spectre77's Avatar
Absent of finding a stock rim. Would you happen to know what offset/backspace should I look for in an aftermarket one that will come close to meeting my needs?
post #7 of 15 (permalink) Old 09-02-2017, 11:39 AM
alleged moderator
no idea on that, i do not run aftermarket.
Spectre77 likes this.
tom
post #8 of 15 (permalink) Old 09-02-2017, 03:34 PM Thread Starter
Spectre77's Avatar
So I've been searching for stock rims and I found several I like but they're all from 2016 or 2017 Ford super duty's will those all straight on or do I need an adapter for the 2003 truck like some of the ads are saying? Thank you
post #9 of 15 (permalink) Old 09-02-2017, 03:53 PM
Turd-250's Avatar
Bolt pattern is the same from 99 to present I'm pretty sure
Turd-250 is offline
post #10 of 15 (permalink) Old 09-02-2017, 03:54 PM
Turd-250's Avatar
They might be talking about spacers rather than adapters, who knows. I've read some strange things on adds before lol
Turd-250 is offline
