anyone ever tried this conversion with these lights? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 02-21-2010, 03:25 PM Thread Starter
roughneck0913's Avatar
99 00 01 02 03 04 FORD F250 SUPERDUTY HARLEY HEADLIGHTS : eBay Motors (item 380206192710 end time Mar-13-10 22:09:31 PST) maybe a good deal maybe not i kinda wanna try them i love this light look
roughneck0913 is offline
post #2 of 20 (permalink) Old 02-21-2010, 03:27 PM
Re: anyone ever tried this conversion with these lights?
Are you asking if anyone has swapped out stockers for harley lights? If so then yes people have done it before.
02 f250
countryboyrob is offline
post #3 of 20 (permalink) Old 02-21-2010, 03:43 PM
5 days
taylorfettig's Avatar
They'll drop right In
01 F250 6 inch lift.. Diy reg return, ts 6 pos. 08 bed and tailgate.
taylorfettig is offline
post #4 of 20 (permalink) Old 02-21-2010, 06:17 PM
spock1996's Avatar
this is right off the ebay page:
Fits Models / Applications:
Ford Super Duty Pickup Truck F250 / F350 / F450 / F550 2005-2007 (All Non-Harley Davidson Models) - Direct Replacement
Ford Super Duty Pickup Truck F250 / F350 / F450 / F550 2005-2007 (All Harley Davidson Models) - Direct Replacement
Ford Super Duty Pickup Truck F250 / F350 / F450 1999-2004 (All Models) - H13 wire harness supplied for you to do the conversion, YOUR PRESENT SOCKET IS A 9007, JUST SPLICE IN THE H13 SOCKETS ( SUPPLIED WITH THIS KIT ) IN PLACE OF YOUR 9007 SOCKET. YOU WILL ALSO HAVE TO CUT OUT BEHIND THE LIGHT AS THESE LIGHTS ARE A LITTLE DEEPER, BUT ITS VERY EASY. ALL THE MOUNTING HOLES ARE THE SAME.
99 1/4 F-350 7.3L, 4" Dp, Dual 5" Exhaust, Van Turbo, K&N, PHP FU 6-chip, DIY Gen3 HPOS, My Own Fuel Filter/Return, Built Auto Trans with PI Stallion Converter, Detroit True-Trac Rear, 2003 Dana-60 Front, Traction Bars, Gauges, Ford Racing Speed Recalibrator.
spock1996 is offline
post #5 of 20 (permalink) Old 02-21-2010, 06:19 PM
spock1996's Avatar
we got a truck at work with these on and i think it uses the same mounting holes as the fleet glass bulb mounts but the header pannel has to be trimmed a bit on older superdutys
post #6 of 20 (permalink) Old 02-21-2010, 08:03 PM
<---Beer version of PMR's
Seven3Leeter's Avatar
I did the conversion a couple of years ago with Harley lights from ebay, I think the ones I have are Bright Eyes or Night eyes, maybe these are the same make. They look nice and shine fine, been meaning to upgrade bulbs. These do allow moisture into the housings, not the same quaility as oem, but I love the look for the price. I bought the coverision harness from dfuser, and used a dremel to cut out the header panel.
Tuning by Sniper
Transmishing by John Wood
Breathing by AFE
Exhausting by Pinncle
Monitoring by me and Isspro
Compressing by Wicked Wheel
Wasting by Turbomaster
Stopping by Powerslot
Lifting by Donahoe
Rolling by Toyo
Protecting by Ranch Hand, God, and Ruger
Addiction by
[SIGPIC][/SIGPIC]
by Garrett, Alliant, ITP, DP-Tuner
Seven3Leeter is offline
post #7 of 20 (permalink) Old 02-21-2010, 09:11 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
They leak... thats about the only issue with them... Grease the gaskets might help, but it is what it is...
Joe
CSIPSD is offline
post #8 of 20 (permalink) Old 02-22-2010, 10:01 PM Thread Starter
ha ha alright I was thinking of getting them and puttin them in my 2000 they looked bad a$$ so I thought i'd see if anyone has used them and did the conversion.... thanks all for the replys.
post #9 of 20 (permalink) Old 02-26-2010, 05:04 PM
Diesel Sled Head
zx800x's Avatar
I put them in my 2001. Just have to cut the header panel to fit. No big deal.
2001 f250 H2E,BTS,Stealth,reg return,mod IDM, spearco,DI Ceramic Headers.. bcode stage 3's Cale's Tunes
zx800x is offline
post #10 of 20 (permalink) Old 02-26-2010, 05:19 PM
Jomax's Avatar
Did you guys ever think of just putting silicone around the seals to keep the water out?? for the non OEM
2000 F-350 4x4 DRW 200,000 miles DP tuner Stock, 40T, decel, 60T, 80T, 80eco, 120race, ported compressor housing, bellowed up-pipes, Terminator T-500, FPR Spring mod, AIH delete, autometer ford factory match boost, pyro, trans, HPX crossover tube, AFE Stage II CAI, 5in Straight pipe, JW valve body, Deep transmission Pan with magnet
Jomax is offline
