35 inch tires - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 02-19-2010, 01:36 AM Thread Starter
snow cowboy
jpzjr32's Avatar
Send a message via AIM to jpzjr32
35 inch tires
i need new tires so i was going to upgrade to 35s my probe is everyone around here wants the size so i was wondering if i got it right im gonna get the bfgoodrich allter. t/a's so are 375/60/18 35 inch tires for my 18 inch rim any help would be great thanks
2006 f350
crew cab 6' bed
sct sf3 tuner w/custom tunes
4inch turbo back straight pipe (6 inch stacks)
cold air intake
arp headstuds
intake mamifold with intake pipe
painless turbo timer
fuel system
175 cc injectors
all thanks to Ken at KT Performance
and many more physical mods
jpzjr32 is offline
post #2 of 8 (permalink) Old 02-19-2010, 02:14 AM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
Re: 35 inch tires
umm Joe, those are gonna be a TAD bit big, unless your getting a decent amount of lift.
for the metric sizes, Take the 1st number multiplied but the second number as a percentage, then divide that number by 25.4 (millimeters per inch) then multiply by 2 and add in the rim size.
375 x 0.60 = 225mm
225/25.4 = 8.858in (sidewall height)
(8.858 x 2) + 18 = 35.72"
and the width of the 375 is
375/25.4 = 14.76
For a reference you know my truck and tires, they are 34.88in x 13
If your sticking to the stock rims you should be good with a straight 35x12.5 or so.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #3 of 8 (permalink) Old 02-19-2010, 10:50 AM Thread Starter
snow cowboy
jpzjr32's Avatar
Re: 35 inch tires
ya i am stickin with the stock rims and i just want a 35 on it but im not havin much luck gettin the right size
2006 f350
crew cab 6' bed
cold air intake
arp headstuds
fuel system
175 cc injectors
jpzjr32 is offline
post #4 of 8 (permalink) Old 02-19-2010, 11:28 AM
Master of Disaster
DevilDocTater's Avatar
Re: 35 inch tires
Ok got a question im looking at some 325/85/16 what size are those?? These sizing things confuse me. I have a 6inch suspension lift, think they will fit?
2004 F-350 6.0 6" lift 35's 6spd MANUAL 4" Turbo Back Exhaust, (ARP's,New HG's EGR Delete from RCD Coolant Filter, 4 gauge pillar with Autometer Phantom Series 1 gauges. Boost, Pyro, Fuel Pressure and Oil Temp. Shimmed FPR. FabTechs.Improved Banjo Bolts, SCT X3 by RCD
DevilDocTater is offline
post #5 of 8 (permalink) Old 02-19-2010, 11:33 AM
PSDfan99's Avatar
Re: 35 inch tires
At the top of the screen is the word "Calculators", click that and scroll to the bottom of the page and punch in your tire sizes and it converts it for you.
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #6 of 8 (permalink) Old 02-19-2010, 12:56 PM
Stroker67's Avatar
Re: 35 inch tires
I'm running 35X12.50R20 MT Baja ATZ's on my stock rim and not leveled or lifted. I had the metric tires on my truck originally but I just went with the standard this time around with my Mickey's.
Stroker67 is offline
post #7 of 8 (permalink) Old 02-19-2010, 12:58 PM
Wondering what if
123rday68's Avatar
Re: 35 inch tires
Have you tried looking online for some, then ordering them. I ordered mine from 4 wheel parts. Others have used National Tire and Wheel. Then when you get them in find a place that will install them reasonable. I called around and ended up going with Belle Tire for mount/balance and had them perform an alignment as well to make sure everything was good to go. Had slight toe in on right so was corrected. Sure it took a little bit to get shipped but at least I got what I wanted and it was cheaper than what the shops wanted around here to order through them. Good luck.
'07 F350 3" lvl, fndrs trmd, 37" M16's
Ultra lites ECT,EGT,EOT Oil and top fuel billet caps
banjo bolts drilled cautiously, ccv, zoodad mods Dieselsite coolant filter
SCT SF3 can tunes
Mike's Diesel Performance
KT Performance
DieselPowerProducts.com
Dieselsite
123rday68 is offline
post #8 of 8 (permalink) Old 02-19-2010, 01:27 PM
Re: 35 inch tires
I have stock 20" rims and just ordered some 295/65R20 Nitto Trails from Discount Tire Direct....you cannot beat their prices, their warranty, or their customer service.
The 295 is a tad taller, but a tad narrower than a 35x12.50R20....which makes more since on the stock 8" rim (less sidewall bulge).
weave is offline
