Light bar power issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 07-05-2017, 03:29 PM Thread Starter
I have a small (20") LED bar installed. There's a toggle switch on the dash and a relay mounted nearby. When I turn it on, my CEL will come on momentarily and the engine loses power for a second. Ideas? I used decent gauge supply wire, and it CANT be drawing much current. Ideas?
tmsbandman is offline
post #2 of 14 (permalink) Old 07-05-2017, 03:56 PM
Moderator
Sbluke55's Avatar
Re: Light bar power issue
So the light bar is causing interference with the cam sensor. Is it an oem sensor.
You could add some ferrite beads I fix it.
01 f-250, Standard
Sbluke55 is offline
post #3 of 14 (permalink) Old 07-05-2017, 07:06 PM Thread Starter
Interesting. Is it the current draw, or the actual LEDs themselves? By ferrite beads, do you mean the little donut magnets that are on some electronics? If so, where should I put them?
post #4 of 14 (permalink) Old 07-05-2017, 09:46 PM
Moderator
Sbluke55's Avatar
It's the leds causing noise and screwing with the cam sensor.
I would try a new cps first.
01 f-250, Standard
Sbluke55 is offline
post #5 of 14 (permalink) Old 07-05-2017, 09:58 PM Thread Starter
The cam position sensor was just replaced a few weeks ago by ford when I got a fuel pump. What would be the next step?
post #6 of 14 (permalink) Old 07-05-2017, 10:10 PM
Moderator
Sbluke55's Avatar
How about the icp sensor. Is it oem?
01 f-250, Standard
Sbluke55 is offline
post #7 of 14 (permalink) Old 07-05-2017, 10:31 PM
Bugman's Avatar
Do you have a dedicated ground to the light bar?
Bugman is offline
post #8 of 14 (permalink) Old 07-05-2017, 11:56 PM Thread Starter
Sorry. Yes (better be). Work
Was done at a Ford dealer.
post #9 of 14 (permalink) Old 07-05-2017, 11:58 PM Thread Starter
Oops. Wrong spot. Yes, it better be. Repairs we're done at a Ford dealer
post #10 of 14 (permalink) Old 07-05-2017, 11:59 PM Thread Starter
Negative from light bar is grounded directly
