parking brake - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 02-16-2010, 01:04 AM Thread Starter
mrgto's Avatar
parking brake
Has anyone had their parking brake mess up on them. Mine has been stuck down 3 times now and i getting tired of it. 1st time i had to cut the cable. If anybody has any fixes for this or help please let me know!
mrgto is offline
post #2 of 5 (permalink) Old 02-16-2010, 03:17 AM
All done now
Arisley's Avatar
Re: parking brake
Take everything apart, lube everything up. Replace brake pads. Make double sure everything is working free.
Not trying to be a SA, but if my e-brake was locking up on me, I would either do that or just never, ever use it.
And you are correct, on these trucks, it is a parking brake, not an emergency brake. If your brakes ever fail, drive out of it, don't try to e-brake out of it.
Arisley is offline
post #3 of 5 (permalink) Old 02-16-2010, 10:38 PM Thread Starter
mrgto's Avatar
Re: parking brake
I know my brakes are working fine. I have been through my brakes from front to back, not for this reason just because i like tinkering. It is the parking brake mechanism that is under my dash that is always locking up. It is a pain in the rear to get to it to work on it.
mrgto is offline
post #4 of 5 (permalink) Old 02-16-2010, 10:56 PM
bobvillaoftn's Avatar
Re: parking brake
my buddies 88 done the same thing, he'd pull the release and someone would jerk the cables for him.
05 f350 CCLB 4x4 delete and sct x4 thanks to innovative
Originally Posted by RedSmokey View Post
Sh*t in a box (litterally) and write "Will give you 200+ hp, just add to your fuel" on the box and give it to him. Then ask him if he still believe's everything thats written on a box...
Originally Posted by bruce51d View Post
if you can blow up a 7.3 just imagaine what you would do to a 6.0
bobvillaoftn is offline
post #5 of 5 (permalink) Old 02-16-2010, 10:56 PM
F-25000's Avatar
Re: parking brake
i had it happen to me about 4 months ago. ended up cutting the cable. once i cut it and there was no pressure on it i found the piece that locked it up. it had just fallen out of its normal position. so i just tightened my parking brake up and hasnt happened since
2004 F-250 regular cab long box, 6.0 w/ 6 speed, 4" turbo back exhaust, airaid airfilter, SCT, Sinister coolant filter, ARP studs, EGR delete, gauges- sold
2010 F-350 crew cab short bed Lariat. 6.4l with auto trans. Deleted and tuned.
Dylan
F-25000 is offline
