Rear Lift Blocks....What Size?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Closed Thread
post #1 of 74 (permalink) Old 02-15-2010, 09:39 PM Thread Starter
BRING DA AMBALAMPS
stroke of luck's Avatar
This is kind of a continuation of my other thread but I put a 2.5" kit up front and now I'm wanting to put in some rear lift blocks to even it out. The front is currently sitting about 1 1/4" higher than the rear. I can't really decide between a 3, 3.5, and 4" block to swap into the rear. Ideally, I'd like to get a f350 block but the stealership charges waaaay to much and i haven't found one on this site or any other for that matter. Anyways, have any of you done this and if so, what size block did you use and do you have pics??
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #2 of 74 (permalink) Old 02-16-2010, 01:13 AM
white7.3's Avatar
Re: Rear Lift Blocks....What Size??
i used 2 inch blocks on mine and it sits rite around 3 inches higher in the rear...
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
6.0 I/C Van Turbo & WW
6637 Intake 5" Exhaust
Custom RR Fuel System
05 Grille/08 Center Console
Raptor 372 w/ Toyo Open
Country AT2 35/12.50
white7.3 is offline
post #3 of 74 (permalink) Old 02-16-2010, 01:22 AM Thread Starter
BRING DA AMBALAMPS
i'm assuming you mean you stacked a 2" block on top of the stocker 2" block right? i've looked into doing that but I think I'm getting a little bit of axle wrap and adding a pivot point could make it worse. I'm not a hundo percent sure but some say stacking is ok and some stay not to so I think I'm leaning to just swapping out the stock for another taller block. looks really good though!
post #4 of 74 (permalink) Old 02-16-2010, 01:24 AM
Tonka Truck
richestates's Avatar
stroke of luck.... I sent you a pm.
99 F-350, 7.3 diesel, 6" lift, 37" tires, 18" wheels, yellow paint with chrome accessories and tonka emblems, line-x spray in bed liner, crocodile leather interior, billet inserts. Getting ready to all change!
richestates is offline
post #5 of 74 (permalink) Old 02-16-2010, 01:27 AM Thread Starter
BRING DA AMBALAMPS
Back atchya...
post #6 of 74 (permalink) Old 02-16-2010, 01:41 AM Thread Starter
BRING DA AMBALAMPS
Anyone know for sure if blocks from a 99 can swap into an 05 and vice versa?
post #7 of 74 (permalink) Old 02-16-2010, 01:46 AM
MINK
Comp7.3's Avatar
yes they can...same block for 99-07
Josh Mink
CAMB MOTORSPORTS
Comp7.3 is offline
post #8 of 74 (permalink) Old 02-19-2010, 10:57 AM
i need some 2 " blocks have a 4" factory on my 350 and its too tall
RWOODY is offline
post #9 of 74 (permalink) Old 02-19-2010, 03:09 PM
Phiber Optik's Avatar
if you are going to remove the stock block you should get a new one that incorperates the bump stop (like a factory block)
2008 F-350 CC SB Lariat, 4wd, 20x12, 35x14.5, 4" lift w/ Bags, 4" Exhaust, IC Pipe, Elbow, S&B Intake, EGR Delete, Gearhead Tunes, Hellwig Sways, Recon Ltng
2000 Corvette - JT Trim Vortech
2007 HusaberG FS650
2008 RZR - Z1 Turbo
Phiber Optik is offline
post #10 of 74 (permalink) Old 02-20-2010, 04:40 AM Thread Starter
BRING DA AMBALAMPS
fyi...i have a set of lift blocks coming from Precision Metal Fab. New concept that incorporates the u-bolts into the block. I'll have a write up with pics, reviews when I get them on
Closed Thread
