Battery Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-15-2010, 12:36 AM Thread Starter
Stroked Smoke
tls390's Avatar
Battery Question
My batteries seem to get a little low after a week or so. I do not drive the truck daily. It seems to charge fine. I put a meter in series with the batteries and have around .2 to .25 draw on them. From the reading I have done here that seems to be about normal. I have had the batteries tested and they passed the load test. The truck seems to start after a week or so, but rolls over slow. Finally here is my question - I have mismatched batteries in the truck, can that cause them to drain? Neither of them are very new one is 1000 cca and the other is a red top 850 cca.
Thanks,
Tim
2000 F-250 Crew Cab Shorty Auto 4X4 (116,000)
4" Lift 35's
EBPV delete, AIH delete, Foil delete
TS performance 6 pos (custom tunes from Rockin-S)
4" Exhaust
Ice Box intake
Tru-Cool and BTS Valvebody
Coolingmist Water
1.0 housing and turbo master
tls390 is offline
post #2 of 9 (permalink) Old 02-15-2010, 04:09 AM
Genius, when I drink
ditch_dawg's Avatar
Re: Battery Question
First I would check all of your battery connections even the grounds, makes sure everything is clean and tight. If that does not 'fix' things then I would disconnect the batteries in between drives and see if the issue is still there. If it is it would indicate that with the batteries are this issue. If that is not the issue I am not sure where to look next.
'03 F250 CC
"Beer is proof God loves us and wants us to be happy" Benjamin Franklin
Originally Posted by golfer View Post
blip the throttle, and you just changed your "HPOP" oil
put that on youtube
ditch_dawg is offline
post #3 of 9 (permalink) Old 02-15-2010, 05:13 AM
PSN Pretender
907DAVE's Avatar
The rule of thumb for a parasitic draw is that .005 amps or less IS acceptable.
You have a draw, to pinpoint your draw you can start pulling fuses until the draw goes away, then diagnose that particular circuit. But you must leave your meter hooked up in series with your battery cable for at least 45 minutes. There are modules on the vehicle that will stay active after the key is turned off, after a while they will turn them selves off. Also do not open the door during this period or you will have to start over. A good practice is to open both doors and close the latch with a screwdriver, this is so the GEM module thinks the doors are shut and will "go to sleep" and you can further diagnose your problem if you need to move inside your cab.
Dont forget that the alternator can draw battery's down also, so you might have to disconnect it to check.
If you are worried that the other battery is causing your draw just disconnect it and re-check current draw.
Good Luck
907DAVE is offline
post #4 of 9 (permalink) Old 02-15-2010, 10:41 PM
Need a ride.
Strokerstooge's Avatar
Cardinal rule of thumb, always replace both batteries, never just the one thats bad. The bad one will pull down the load of the new one.
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
post #5 of 9 (permalink) Old 02-16-2010, 02:39 PM Thread Starter
Stroked Smoke
tls390's Avatar
Thanks for the info. I am out of town right now, but will try that when I get back.
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #6 of 9 (permalink) Old 02-16-2010, 02:48 PM
Buffalo Diesel
If you can swing it, I'm very happy with my Walmart batteries, $75 each. 3 yr free replacement, 9 year pro-rated.
I'd trace down the problem first though.
2000 F350 CC LB - 250cc 200% - Matt Tuned - 9" Lift - 38" Extreme ATs - Vegistroke
Jack_Toepfer is offline
post #7 of 9 (permalink) Old 02-22-2010, 01:56 AM Thread Starter
Stroked Smoke
tls390's Avatar
I waited the time and used a better meter this time. The draw was 2 mA
(.002). Apparantly the meter I used first was not that accurate.
I had a trickle charge on them all week until around 4. I did all my testing and around 7 decided to have the batteries tested again. They both passed, but said they had low charge voltage. They both dropped to high 10 volts with load and came back to just over 12. I am thinking that the batteries might be the culprit. I am a believer in replacing both, but unfortunately my truck had mismatched batts when I bought it.
Thanks for all the help.
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
post #8 of 9 (permalink) Old 02-23-2010, 12:05 AM
Steamfighter
Steamfighter's Avatar
My batteries , no load , truck off, 12.6 volts . just after starting, ( glow plugs still lit ) 11.9-12.4 , 13.6-13.8 idle , no accessories on . 4 year old factory batteries .
2006 F350 6 wheeler. some mods done thanks to First Coast Diesel Performance , but more to come!! .
Steamfitter local 602 Washington D.C.
2005 F250 OVERLOADED WORK HOSS
Steamfighter is offline
post #9 of 9 (permalink) Old 02-27-2010, 03:47 PM Thread Starter
Stroked Smoke
tls390's Avatar
After a week of the batteries unhooked they both read 12.78 volts. So I went back and checked for a draw again. Like and idiot when I switched meters the new one defaults to AC amps where the old one defaults to DC. I read 208 mA dc. I have tracked it down to the brake controller and the GEM. The brake controller had 44 mA draw. The GEM is drawing 164 mA. Does anyone know where the best place to get one of these? Are they dealer only? $??
Thanks
4" Lift 35's
4" Exhaust
Ice Box intake
Coolingmist Water
tls390 is offline
