BEST TIRES - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-15-2010, 12:22 AM Thread Starter
BEST TIRES
I have a 02 for dually that Im converting from 2wd to 4wd. Im going to keep it as a dually but I want a good set of tires to put on it. Which tires and what size?
jaredb is offline
post #2 of 13 (permalink) Old 02-15-2010, 12:40 AM
Firefighter/EMT
NH OIL BURNER's Avatar
Re: BEST TIRES
if you can get them for the dually, i have always ran BFG Allterrians. The hold up really well!
02 F250 6 speed with 270k- SOLD
05 F350 auto with 94k, 4in MBRP with 6in tip, updated fuel pressure spring, and auto meter fuel press, boost, trans, and pyro guages, and tuning by vivian and PHP's FICM tuner currently running hercules! NO STUDS!
14.1 @ 95 is the best so far!
NH OIL BURNER is offline
post #3 of 13 (permalink) Old 02-15-2010, 01:37 AM
I get's it did!
SledYanker's Avatar
Re: BEST TIRES
35x12.50 Nitto TerraGrapplers with a 3" spacer between the duals...
Oh, and a leveling kit to keep the front from rubbing.
SledYanker is offline
post #4 of 13 (permalink) Old 02-15-2010, 02:16 AM
OBS junkie
Cat_Rebel's Avatar
Re: BEST TIRES
What gears & what do you use it for?
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #5 of 13 (permalink) Old 02-15-2010, 05:33 PM
Myles_S's Avatar
Re: BEST TIRES
Street tires? Off road tires?
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #6 of 13 (permalink) Old 02-15-2010, 05:43 PM
Super Sparky
fine69's Avatar
Re: BEST TIRES
Pro Comp Extreme A/T's or Toyo M/T's!
2009 F350 4x4 CCLB Job 2
fine69 is offline
post #7 of 13 (permalink) Old 02-15-2010, 05:47 PM
<---Beer version of PMR's
Seven3Leeter's Avatar
Re: BEST TIRES
Make sure they are load range E atleast, then depends on what you use the truck for.... I would not go bigger than 35 if towing or not regearing. If hwy use a good A/T, if mixed Use, the toyo M/T is awesome in 315/75/16.
Tuning by Sniper
Transmishing by John Wood
Breathing by AFE
Exhausting by Pinncle
Monitoring by me and Isspro
Compressing by Wicked Wheel
Wasting by Turbomaster
Stopping by Powerslot
Lifting by Donahoe
Rolling by Toyo
Protecting by Ranch Hand, God, and Ruger
Addiction by
[SIGPIC][/SIGPIC]
by Garrett, Alliant, ITP, DP-Tuner
Seven3Leeter is offline
post #8 of 13 (permalink) Old 02-15-2010, 06:42 PM
WHAT???
STROKIN N STYLE's Avatar
Re: BEST TIRES
Toyo mt's
2000 F-250 ex sb 4x4 Swamped 7.3 (CR coming soon)
1999 F-450 cc fb 4x4 Swamped 7.3 (STOLEN)
2008 F-250 cc sb 4x4 H&S, S&B, 5", BMF, Grabbers
STROKIN N STYLE is offline
post #9 of 13 (permalink) Old 02-16-2010, 12:22 AM Thread Starter
Re: BEST TIRES
Towing, hunting, a little off road fun but it is a dually so not to much. 4.10 gears. Highway also.
jaredb is offline
post #10 of 13 (permalink) Old 02-18-2010, 08:38 PM
Re: BEST TIRES
I ran 295 75 16's BFG ATs on my F350 dually for 3 years with 2 inch rear spacers. They worked out great and let me go anywhere on and off road, keeping in mind its a cc long bed dually Stock suspension height, just needed the spacers. This setup worked out well for me.
Tires are getting kinda low on tread now so I am making the jump to a set of 37" pro comp AT's with a 6" lift.
TalontedTSi is offline
