Painting intercooler pipes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-29-2017, 03:21 AM Thread Starter
GaryG's Avatar
Garage
Currently just waiting on warmer weather, but just wanted to find out beforehand what I need to do. So I was able to get my trucks paint code made into rattle spray cans. I know I need to get rid of all the oil and grease on the pipes, which shouldn't be too bad considering i cleaned it with brake clean when I installed the KC38R turbo this past weekend. Then I'll be using 180 - 320 grit sand paper to clean up some surface damage (hopefully), then use 600 grit for the final sanding. What I'm stumped on is if I should use like an adhesion promotor or an etching primer before I use the rattle cans?
My truck is a Deep Tourmaline Metallic, I think it'll be different and definitely stand out when finished, its green but has that bluish look to it in the right sunlight
1999 F-350 CCSB
KC38R Turbo | Hydra chip | CTS2 Monitor | 5" exhaust | NAPA 6637 filter
8" BDS lift | 1" Zone shackle | 17x10 Fuel Maverick D538 wheels | 37x13.5 Cooper STT PRO tires
Rough Country shocks (duals up front) | Rough Country dual steering stabilizers | 2008+ tow mirrors | Thunderstruck front end replacement, Spyder headlights
GaryG is offline
post #2 of 4 (permalink) Old 03-29-2017, 01:14 PM
410customs's Avatar
Re: Painting intercooler pipes
Use a good primer before you spray your color, that should be it. They are metal no adhesion promoter needed unless they are some sort of plastic.
2001 Excursion 7.3, auto, 4x4, 3.73, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liter family
410customs is offline
post #3 of 4 (permalink) Old 03-30-2017, 03:18 AM Thread Starter
GaryG's Avatar
Garage
Alright thanks. One thing I forgot to ask, when I spray the pipes, should I mark a line and tape it off at the line? (it'd be where the boots would go). Or is it ok to spray the entire pipe?
1999 F-350 CCSB
GaryG is offline
post #4 of 4 (permalink) Old 03-30-2017, 12:22 PM
Banned
Don't spray whole pipie boots won't grip that well to painted surface.
sideswipe7 is offline
