Need wiring information for towing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 12-31-2016, 06:58 PM Thread Starter
Exclamation Need wiring information for towing
Just got a 2003 F-350 6.0 with DRW. The trailer towing pigtail (the factory pigtail under the bed that the 7 pin wiring harness plugs into) appears to be completely dead. I need to know where that originates (engine compartment, under dash) so that I can trace back where the problem is or just completely run a new 7 wire cable. Any help is appreciated.
jst3751 is offline
post #2 of 2 (permalink) Old 12-31-2016, 07:29 PM
alleged moderator
tjctransport's Avatar
Re: Need wiring information for towing
unless the fuses were put in, nothing in the tow plug will work. that plug is fuse protected from the rest of the truck.
tom
tjctransport is offline
