Backup Cam/Firewall question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-21-2016, 02:31 AM Thread Starter
KTMDirtFace's Avatar
2001 F350 7.3
I'm installing a new cheap ass touch screen in it, and a cheap backup camera.
I spliced the backup camera into the reverse lights. Power and ground, peeled back some of the casing with an xacto and then soldered the backup cam wires to it. then covered in electrical tape.
QUESTION: I need to run the video feed from the back and up to the front, i think its supposed to go through the firewall, is there any existing spots a RCA video feed will fit through? I didn't see anything, or how should I go about getting the video feed into the cab so i can plug it in my new radio.
Backup camera I got
Backup Cam power and ground hooked to reverse lead and ground.
Basically i'm just stuck on how to get the video RCA cable through and into the cab to plug it into the radio.
Thanks
2001 F350 Crew Cab Long Bed.
2010 6.2L Raptor
KTMDirtFace is offline
post #2 of 10 (permalink) Old 11-21-2016, 04:18 AM
Moderator
Sbluke55's Avatar
Re: Backup Cam/Firewall question
Drill a hole in the plastic cover where the clutch master cylinder would be. Then pass the wires through there.
01 f-250, Standard
Sbluke55 is offline
post #3 of 10 (permalink) Old 11-21-2016, 12:41 PM
alleged moderator
tjctransport's Avatar
i brought the wire up the passenger side of the frame and drilled a 1 inch hole under the passenger seat. ran the video wire up through the hole and under the carpet along the trans hump to the dash.
i also ran all the feeds for the strobe lights through the hole to the four corners and mounted the strobe box under the seat.
tom
tjctransport is offline
post #4 of 10 (permalink) Old 11-22-2016, 07:33 PM
I ran mine up on the drivers floor/lower part of the firewall where there is already a rubber plug. Put a small slit in the plug to run the wire through and then ran it under the floor.
Turbospin is offline
post #5 of 10 (permalink) Old 11-23-2016, 12:48 AM Thread Starter
Thanks I found this, someone put some wire through it already for something else. This looks like the best option i'll do a grommet and some silicone for good measure.
Thanks
2010 6.2L Raptor
post #6 of 10 (permalink) Old 11-23-2016, 12:59 AM
s10mike's Avatar
i would ditch the electrical tape, and use some shrink tube.
s10mike is offline
post #7 of 10 (permalink) Old 11-23-2016, 04:00 AM Thread Starter
Yea.....normally I would agree. there was lots of curse words flying when I tried to snip and cut my sled deck into the taillights and brake lights. I did the solder/shrink wrap there. It was a chore to hold the wires myself while soldering.. Should have seen the contraptions I came up with. Helping hand's gorilla taped to my truck and whatnot.
I was running this plug, up so that my sled deck could plug right in without having to run through the tailgate and down to the trailer hitch plugs
For the backupcamera I was LAZY and just took an exacto knife and peeled a ring off the reverse light and reverse ground sheathing, and soldered the backup cam wires too it and wrapped them with tape. Can't get heat shrink on in that case.... Its still probably better than those T-Tap things :)
Edit: I suppose i could paint some plasti dip on them intead of tape or in addtion, without having to cut and shrink wrap.
2010 6.2L Raptor
post #8 of 10 (permalink) Old 11-24-2016, 12:29 AM
lewismug's Avatar
There was a rubber grommet in the driver's rear corner of my 97 that I ran mine into the cab through.
Sent from my SAMSUNG-SM-G900A using Tapatalk
1997 F350 7.3 PSD CCLB 4x4 Auto 310,000 miles Bone stock
lewismug is offline
post #9 of 10 (permalink) Old 11-24-2016, 07:45 PM Thread Starter
Another question:
Where is the black and pink wire for reverse? So i can hook up to my stereo so the camera kicks on in reverse?
I saw a video on youtube but it was for an 02.. and my fusebox is way diffrent ( I have a 2001 F350 ). My fusebox is really wedged in there really hard to even get at the back of it.
I found a black and pink wire going to the steering column but its just a ground/link not hot.
2010 6.2L Raptor
post #10 of 10 (permalink) Old 11-24-2016, 11:21 PM
alleged moderator
i answered in your other post.
tom
